0 Members and 317 Guests are viewing this topic.
Сергей В.
Привет NickZ
Thanks for your reply. If Akula didn't answered to you - you can ask Vitaly aka Tiger 2007.  He has personaly visited Akulaand gave him many useful instructions. You should contact him on http://realstrannik.ru/forum.html. Login and ask him - Try maybe he will said you some important informations. He have a great experience and many years in research and experimentations.
About Akula device and your schematic.
I think you have correct noticed some errors in T100 schematic.  They are several. First is: NF 100 HZ modulation of TV yoke. It's wrong. Akula used about 35kHZ-50kHz in his induction heater. He used powerful IGBT transistors with low Rce heavy cooled drived by High Current Driver IR2110 or 2113. TL494 can't give more than 260mA on output to charge gate capacitors of IGBTs as fast as possible or 520mA in parallel but you should make another inversion of signal for other transistor. Better aproach is using some of special driver for it. Of course you can make your own high speed driver with superior current output capabilities, Problem in self made driver is you need good oscillograph to check the signals and signal paths to avoid ground looping and self oscillations on input. In such high speed driver the carefull and optimal desing of PCB is crucial thing. If you didn't done this befor better take factory driver. Some of them UCC37322 UCC27425 IR2153 TC4420 etc. For long time application you shouls think about Water Cooler for transistors.
Wire for your TV yoke windings is not good. Use very thick wire both for primary and secondary windings 10mm2-20mm2.
If you haven't such thick wire make it from 4-6 wires like wires on your photos, twist them all with some Electric Drill and wind on TV yoke. If need use bigger TV yoke.
Second. 50 Hz modulation can be done using output of invertor 12V/220V 50Hz. Look on SR193 transformer and especially L2 coil carefully !! It have 2 opposite Bifilar Coils in counter-plan with several centimeters space between. Start of one connect to the end of second. Bifilars must have great number of turns with a thick wires. For example like in schematic i have posted earlier  2 insulated wires 0.75mm2 40-60 turns wounded together in parallel and conected if bifilar manner for one bifilar and same do for 2nd but wound in counter plan (like head wind) with space 7-8 cm or smaller. Both coils must be freely moving along the same axis for fine tunung. Both end conect with invertor output 220V/50Hz.
Third Output coil.
Clasic coil with 80-100 turns thick wire 2.5mm2-3 mm2 in good isolation.
Fourth Inner coil or lambda/4 choke coil
Inner coil should be choke of many turns of thin enameled copper wire conected on good high voltage impulse capacitor with low ESR. Choke should be lambda/4 or multiple of lambda/4 main oscillator frequency 35khz-50khz. Use microwawe owen HV capacitor. Also other capacitors should be impulse type HV with lowest ESR and working voltage mor than 1kV.
You need one coil to take some output power for about 100-120w, rectify it and bring it to inverter input in for of direct current 12v,10A heavy filtered to power your invertor and electronic. Try to get anywhere one oscillograph and signal generator. You should have it for tuning and experiments. Try on ebay you can obtain nice osciloographs from 50 bucks to 250,000!! Or change your mobile phone for low price oscillograph. When tunig 50Hz modulation windings on Double Bifilars maybe you shoud connect one or two non-polarised capacitors is series with them or some incandenscent light bulb not led bulb. Main oscilator should run on 12V accumulator. Must be very good shealded and shield grounded. For ground use heavy cooper bars sticked in your backyard and heavy flooed with water. Ocean water is perfect for it !! To rise power transfer try ferrite sausage. Make it from many ferrite rings about 4-5 cm in diameter glued together or you can experiment with alumina, copper, brass, silver tube inside your coil. Tube need to be cutted along the whole lenght to avoid electromagnetic short circuiting.
NickZ have you built oscillator on TL494 with independent tuning Скважность (reciprocity of Duty Cycle) and Frequency?? If you did give me schematic i would like to see.
Nick Vitaly DON'T speak english so no sence to ask him to come on english forum. I said log yourself on Realstrannik  forum and ask people there !! Use translator for example
http://www.translate.ru . Ask short and precise questions and i think some of people will answer you !!
to verpie
Mr a.king21 has right 100%. Another man which you should visit and do some measurement is Ismail Aviso at Manila Philippines. Contact him or his friend Konehead for more references and instruction. I am pretty sure you will change your mind about Energy Aetheric conversion after your visit and several experiments in his lab.
NickZ
  @ Cepren B:
   Ok, thank you, I'll try to contact Vitaly. I have been studying all his videos as well. But, I think that he is very uneasy about telling and showing all he knows. I can't blame him. Maybe ask him to come to our forum, also, if you can.
  Every generator that is spinning coils around magnets, or the other way around is a free energy generator, as the energy that is produced is ALL coming from the surrounding ambient, not from the input source.  But, many like Verpies will not accept that. They will have many reasons as to why that is not so. But, no proof,  ever.
   Don't waist your breath, it's useless. They know it all.  All the proof in the world will not change their mind.  His true and unchanging belief is  "TESLA is very wrong".    There you have it...
  a.king: even the new Magnacoaster device will not change his mind, either, or others like him.
You'll see...
  That is precisely why they don't have one, and never will, unless they buy it from those that KNOW how it's done. As they don't even think that it's possible, even if they were holding it in their hands, and watching it work.  Each to his own...
NickZ
  "About Akula device and your schematic.  Quote from Cepren B.:
I think you have correct noticed some errors in T100 schematic.  They are several. First is: NF 100 HZ modulation of TV yoke. It's wrong. Akula used about 35kHZ-50kHz in his induction heater. He used powerful IGBT transistors with low Rce heavy cooled drived by High Current Driver IR2110 or 2113. TL494 can't give more than 260mA on output to charge gate capacitors of IGBTs as fast as possible or 520mA in parallel but you should make another inversion of signal for other transistor. Better aproach is using some of special driver for it. Of course you can make your own high speed driver with superior current output capabilities, Problem in self made driver is you need good oscillograph to check the signals and signal paths to avoid ground looping and self oscillations on input. In such high speed driver the carefull and optimal desing of PCB is crucial thing. If you didn't done this befor better take factory driver. Some of them UCC37322 UCC27425 IR2153 TC4420 etc."
  I totally agree with you that a commercially made driver, which can be obtained (salvaged) or bought ,or even adapted to include a duty cycle, and frequency adjustment, is the way to go.  If you know of one or two of those drivers which can be made to work for the Akula application, that is precisely what I need. That would also be the best for everyone interested in this kind of replication. As the rest of the device is a piece of cake to build.
Сергей В.
Akula device isn't a peace of cake !! It's complex in many aspects otherwise many people would be made their device without any help.
Schematic of very speed driver - tested and checked you can find somewhere on this thread. Little time you will need to find on internet. Search for handy made driver for IGBT or MOSFETs.
NickZ
  Ok, I'll check into the ready made Mosfet drivers.  If you find some that may be the best for this application, please post a link to it. As to me that is the main hang-up with building this device.
  I have several of these 110v 65 watt CFL bulb mosfet drivers (pic below), which seam very similar as to what he is using, and possibly the trim pots to adjust frequency and duty cycle can be adapted, also.
  Today there was practically a huricane wind force tropical storm in the capitol area of Costa Rica. Even 1/2 inch size hail fell, many houses lost their roofs, fallen trees, power lines down, much damage.  I'm ok.
Also, no electricity in some parts of the country. This can happen anywhere, at anytime. Good to have these devices working, at least as an emergency back-up source, or permanent ones.
  CFL bulb driver:
