0 Members and 74 Guests are viewing this topic.
Void
Quote from: Sergh on February 02, 2018, 03:56:37 AM
There is no interesting here - this is not a "time reversal".
Hi Sergh. Yes, it was most likely just something interfering with the scope tracing.
All the best...
AlienGrey
Lads any chance we can terminate the scope 'jokes' and move on, the tread, if I can remind you is about the Daily OT device
any chance we can discus ideas on this subject and or hardware directly to do with this item.
To help you I have posted a Photo of Adrians Kacha coil that might be of interest to those who are seriously interested in
solving this mystery.
Allen
Belfior
Is the foil there to catch ALL the energy that the coils produce?
Like this guy does https://www.youtube.com/watch?v=BdBjKVyKBZA
Is this the secret? Get the coils in resonance to get extra and then use the copper foil/pipe to catch it?
NickZ
  My Kacher primary coil is also placed in the center of the secondary coil. That's where it works best, in my case also.
  The copper foil is not really visible in that image, but if placed there it probably make no real difference.  In any case, try it and see.
  There are many things that were changed from the first version tests. The foil is probably one of them.
Adrian was replicating Stalkers device and schematics. Which did work, just using a simple Kacher circuit.
   The extra long Kacher secondary coil would probably produce too low of an output frequency signal,  if using it's full size.
   Geofusion:  Anything new??? We need to discuss what does not work, as well as what does work. So, please keep in touch with your recent tests and results.
   Apecore: What's new with your set up?
   So far, I don't see any "extra" output when the Kacher is also on. Just higher draw from whatever is used as the input source. Instead of the other way around.
   If using 100w bulbs, or higher wattage bulbs, my feed back circuit will not power the PS used for looping the device. The feed back PS will only works to produce 24v, when using a load of a single 25w bulb, or other low wattage bulbs.  How about YOU...
T-1000
Quote from: Belfior on February 02, 2018, 08:55:31 AM
For better understanding why foil/etc the book in PDF -  https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg499309/#msg499309
Then possibly we can have discussion from that approach... :)
