0 Members and 101 Guests are viewing this topic.
AlienGrey
Quote from: apecore on March 22, 2018, 02:16:08 PM
Ok Nick,...  i agree....
The box is half full and not half empty.
Lets look at the vid
So let me help you to get out of the water    and start to find first the differences and or aspects we have reconized in the last vew years
As i can see the following things perhaps for certain:
1- Interrupting kacher .. why?...  because there are some boxes like Ruslan has.. the one in the middle is conneted to the kacher transistor/ fet....and the box has a connection to the box on the right ( the yoke "box")
2- Wesley mentioned the TV yoke..  (Russian)... these could be one with Cobalt... (something what Hoppy would tryout/ look at)
3- There is a extra winding between kacher secundairy and Grenade..  (looks like 2.5mm^2 wire)
4- PS...  seems a normal PC supply..  which in my opinion no special function has in case of missing link/ or magic
5- The Grenade looks like it is wound different then Ruslan's type because the L5L6 windings are equal in numbers Even L3L4 looks like that ( so not in wirelength)...  probally it is a fact that the grenade can be wound differently and is most important that it has a very low inductance in combination of bibilar wounded
6- The Push Pull setup is also same configuration as Ruslan has showed... therefore i asume that the snubber configuration ( as Ruslan also stated to be important) is present here also.......this would match up with the Russian cobalt TV yoke.
7- Unknown is the requenty relation between Yoke// Grenade// kacher...
8- Inductor seems to be longer then 10M...  probally half the length of the grenade wirelength
9- Ground cable connection goes into the Pus Pull box..  this is also different probally the "STAR"groundpoint is located in this push pull box?
10- Antenna and kacher primairy have a fixed wirelength ( kacher primairy is ajusted).. Antenna looks like same lenth as Ruslan's
11- Maybe Wesley knows what wire gauge kacher secundairy is used so approxemately we can guess its fres range...the length of the coil looks like 10- 12 cm as the grenade is close to 20cm...
Do you see more points in which there are learning / discover points?
Greetings
In my opinion there are two directions to look at..
1- the special Russian TV yoke   (Hoppy's Roadmap)
2- The kacher// grenade// antenna etc.  or in other words the charging of the grenade bt the kacher system ..  (Which T1000 has explained several times in last posts)
Some where on here you mentioned a small winding on the end of the katcher, now that is interesting !!
SeaMonkey
The Katcher circuit utilizes the Tesla Coil to achieve
resonance by means of the propagating standing
wave interaction within the Coil.
The Katcher is, in fact, a variant of the Tesla Coil
as are all Solid State versions of the Tesla Coil.
What they have in common is The Coil and differ
only in how the Oscillator RF is produced and
injected into the Coil.
The Original Tesla Coil utilized a Spark Gap
Oscillator to feed The Coil as, at that time,
it was the only way to produce sufficient RF
by means of such Oscillations.
The principles of operation of the Tesla Coil and
all of its variants are very well understood indeed.
NickZ
    Forest:
    The Tesla coil/Kacher circuits are open-ended circuits, unlike other oscillator circuits which are closed circuits such as the JT circuit. But, the purpose of the Kacher in our Akula/Ruslan type of replications, is to add disruptive HV pulses to interact with the MOSFET driven magnetic based induction circuit. There lies the difference in its usage and operations. Not simply to toss HV streamers through the air, as is the case with most Tesla coils, or Kacher circuits.
The point therefore, is not to add HV pulses to the magnetic induction circuit, but to disrupt it,  instead.  In such a way using these several KW pulses, that a third type of output or wave form is obtained, producing yet a higher output than the sum of the first two circuits, when  both circuits are in the proper resonant sync.
Which is the difficult part, obtaining this proper synchronization between the circuits, to be able to obtain and draw enough extra juice from the surrounding ambient, or from wherever, to override all of the associated losses.
Exactly how this all works to allow for self running, is still an unproven theory, and the objective of this thread.
AlienGrey
Quote from: SeaMonkey on March 23, 2018, 08:37:09 PM
Well if your that much of an expert perhaps you would like to explain why
Akula's Ruslan device doesnt work ! and whats wrong so it can be corrected !
thank you !  ;D
And I think you will find Tesla's first Tesla coil was a motor distributor driven ignition magneto type device.
forest
I mean - how and what is causing transistor to open and close and in what sequence and moments. Tesla coil is driven by square generator, if Katcher is somehow auto-adjusting frequency then we have to know how or it's like wandering in big forest without compass
