0 Members and 46 Guests are viewing this topic.
apecore
Quote from: NickZ on April 28, 2018, 01:53:52 PM
    Apecore:
    Can you help me understand about those unipolar pulses?
    Are you saying that the normal kacher frequency lowers to 1\2 of where it was before? Or what frequency does it go to?
Nick,
Ruslan or Akula mentioned that it is important to use unipolair pulses from the anenna.
Or in other words DC puylses,... ( can be positive or negative),....  using both..  like a sinewave...  "the katcher will eat the energie given to the grenade "...(some quote from Ruslan)
THis i s reasonable in order to create the after stroke (lightning) hitting the grenade
So somehow we need to eliminate half the wave from the kacher...  coming out of the antenna..
No we can use fast diodes... and shortn one of these periods to ground,...  i ve did that  but it results in getting double as much as pulses as sinewave half periods....  so my kacher is no longer running on 1.875Mhz but approx 1 Mhz instead.
So now my grenade's resonance frequentie is not matching the kacher anymore.
On the other hand...  using diodes to eliminate half the sinewave period does costs some kacher efficiency,....   therefore...  perhaps a trick with the ferrite or some other colis instead could create the same effect without efficiency losts..
But... again a observation from the working devices .. the ferrite as used by Ruslan or Akula are the normal wound types...  Which in my opinion do not contribute in making the wave from the antenna unipolair.
So here we need some smart guys doing some suggestions in how to do this withut diodes etc.
Greetings
AlienGrey
Unipolar meaning
1.
having or relating to a single pole or kind of polarity.
"a unipolar magnetic charge"
2.
(of psychiatric illness) characterized by either depressive or manic episodes but not both.
Hoppy
Increase the length of the Kacher secondary winding.
apecore
Quote from: Hoppy on April 28, 2018, 02:38:54 PM
Then the frequenty will drop even more..
Hoppy
