0 Members and 169 Guests are viewing this topic.
Hoppy
Quote from: apecore on April 28, 2018, 04:47:14 PM
Unless the position of the burst from the capacitive discharge is at a moment without effect.
What would mean at zerocrossing point of the current... so the magnetic field is zero.
My current understanding is that the resonant current in the grenade needs to be subjected to rapid pulse bursts very close to sine-wave peaks. The unipolar pulses therefore need to be inductively coupled to the grenade. The power of the pulses maybe a critical variable, as maybe the physical and electrical parameters of the pulse transmitting coil.
apecore
Ok....so for practical use i will try to see how to proceed....
1- resonant current...should match the puls freqeunty...
- Grenade adjustment or using 2nd sub frequenty..1.875/2.
2- pulses @ sinewave peaks...this is showed in Ruslan/Akula vids...
3-unipolair pulses inductively coupled to grenade....is also matching at resonant freq.
4- power of the unipolair pulses...... Vcc primairy coil variable
5- physical and electrical parameters pulstransmittercoil......this is the antenna... its length..diameter...and?
This is in general already in scope.. perhaps some more finetuning and decent testing.
But step by step...we will see
Hoppy
Ref your item 5. I'm not sure that a Kacher / antenna arrangement is the best way of pulsing the grenade. I favour the Daly approach.
apecore
Ok...you mean the coax version which Itsu did gave it a try.
Would be a good option.
As it is moreless unipolair and direct coupled... so i think more effective pulsing.
I m not aware if Itsu had adjusted al mentioned parameters....during his testperiod.
But i can imagine that this concept is in for a update period.
