0 Members and 132 Guests are viewing this topic.
Thaelin
Hi Grum:
   Have been holding off on saying this until now. You just proved an idea
that I have had for some time. The free wheeling coil has to be a multiple
of the input freq. If it was resonant with the input, it would show as a dead
short to the input side. I have proved that with just a transformer and a
cap. When it matches, highest current flow happens. You are showing a 3X
value of the input and 12 in, 400 out.
   I have an order pending for the last parts I need. I have an idea that it
may be correct to look at 7X the input freq. In Power factor correction, 7
stands out. Map your phase angle of volts to current.
thay
Nightmare_T34
Quote from: Grumage on June 22, 2013, 04:21:03 PM
Dear Nick and all.
I have been following the diagram posted below. You will note that the internal choke is only connected to the capacitor. This capacitor is what is lining the coil former.
I have started conducting the first of probably many tests!! And using only 12 Volts. First interesting point is that for my device, at around 12KHz on the 7 turn primary drive coil. My resonator ( choke and capacitor liner) was developing 400 V p/p at a frequency of 36 KHz!! In other words in it's own freewheel mode. This resonant point was found by varying the frequency of the drive circuit.
That is a far as I have got. I need to speak with T-1000 in order to procede to the next stage.
So dear Nick I cannot really explain what is going on, only that T-1000 said that a capacitor within a magnetic field will develop a charge on it's plates.
Cheers Grum.
The translation of the Akula shematic is not full. For the inner coil   , that is inside the pipe . Capacity is .68 microfarrads. And also Akula states that the inner resonating coil should be proportional to 1/4 of your wave lenght. Also the original shematic states that the working frequency is from 30 to 75 KHz.  And ALSO ( hopefully it's the last correction of my post ) the measurements of the transformer's base ( pipe ) are missing. The diameter is 12 cm ( 4.72 inches ) and the height is 50 cm ( 19.68 inces ). One more thing.  I see you guys are wondering why the inner coil isn't connected to the circuit. Read some about http://en.wikipedia.org/wiki/Parasitic_capacitance . Might help ( it's just my guess ) . I'm not trying to offend anybody.
Grumage
Quote from: Thaelin on June 22, 2013, 05:38:42 PM
Hi Grum:
thay
Dear Thaelin.
I am pleased to see that you have grasped the significance of my post. Two seperate frequencies runnnig together!! It is a key issue.
Further testing last night saw the dilectric of my "home made capacitor" give up and resonance lost. So today, a remade  one fitted, and lo, completely different results!!
I can't see a way of getting 7 times the frequency. I have been through the range from audible to Mhz but no more than a times 3 was seen. However with my new dilectric I have achieved over 1000 V p/p on the resonator with a 24 VDC input!!
An important BTW........ You get very different results with a PSU compared to a Battery. So please bear this in mind when experimenting!!
Dear Nick.
In answer to your question, no I have not tried to light any lamps yet. At the moment I am trying to get a "feel" of things and to try and understand what is going on. Rest assured you will be the first to know when lamps are lit :)
Cheers Grum.
NickZ
   Grum:
   Ok, no lamps lit yet.
   Obtaining a higher current output than the input source used, is the goal. As Akula mentions that current is what is important. Otherwise it's just an inverter, raising the voltage at the expense of the current source.
   It may be that what is needed is a high current source to get the system stated, along with some higher wattage bulbsas the load, so it will then run itself from the feed back coil. Therefore the battery may work better that a low wattage power supply. But, this I don't know for sure.
   I'm still working on just getting it going, like TK showed on the 2004 back yard video when he was just using a 12v car battery, and converter. I don't know if this is different than an inverter, but Akula has shown that an inverter will also work.
  I was hoping to be able to use a PC back-up source that I have been given, but I find that it's not working right, which is probably why it was given to me. I might be able to fix it though.
   It seams like the way that T-1000 has the rectified 220v DC going to the yoke, then to the coils on the air core should light the bulbs, just by itself even without the rest of the circuit. Almost like connecting 220v direct to the bulbs.  NO?
  Anyway, good luck with your project.
Grumage
Quote from: NickZ on June 23, 2013, 12:54:10 PM
Dear Nick.
Yes you are quite right in your assesment but only partially rectified, the bulbs will light. Half way there :)
T-1000 said something very interesting " We have always been passing voltage and current down the same wire for years. Just think about voltage in one wire and current in another, then mix them at point source"........ Food for thought??
Dear Thaelin.
Just come back from more "coil bashing" I can verify that the capacitive liner DOES play a part. I disconnected the cap from the choke coil and placed an external cap....... Just a flat line, no responce whatsoever!!
Nos Da, Grum.
