0 Members and 123 Guests are viewing this topic.
apecore
Quote from: bolt on July 07, 2018, 02:38:11 PM
Problem katcher is a bad choice its a sloppy sleepy oscillator then keep asking it to sleep for 1500uS then wake up for like 10uS it has a slow start response time as the base current slews all over the place everytime you ask it to wake up so the burst is shitty.  You need a clock driven tesla burst but then you must tune the clock to the antenna and base induction coil aka normal tesla coil tuning.
Hi Bolt,
I think this is a main problem....  no OU because the kacher is too sloppy..
And second ....   to get a sharp unipolair puls from the antenna... (package)
Ok to figure out a differnt way is first to understand its meaning.
Do you agree..  the kacher/ HV burst need to collaps the magentic wave inside grenade/ inducor?
Also what matters is its pulsfreq. ... you should think it has to be the same as the grenades resonance freq. so it excites the grenade?
How about (just suggesting) make the inductor "burst" ... it is clock driven...
I would choose to replace the inductor coil....  and put some capacitor/ coil instead (bifilar foil wounded).... letting it spark at APEX...
Only thing to adjust is to get the Inductor wave synchronise the grenade Voltage wave... If we are clocking the burst moemnt at APEX grenade voltage wave?
I don t know if it is possible,...  but when it works it solves the sloppy issue?
Greetings.
P.s. NickZ,...  are you building yuor interupter already?
AlienGrey
Seems right too me. The kacher will run at any frequency it likes and it doesn't matter. Lets say 1Mhz  You then chop the katcher to provide sync burst to the collector coil.  The collector coil MUST have a known resonant frequency. In the Khz range lets say 38khz it doesn't matter so long as you know what it is.  The katcher sync is then timed to induce and create the collector 38Khz sine wave by precion burst of the tesla coil 1Mhz pulses.  There is no OU yet this is all sync and tuning. Need to add caps and fine tune the collector coil and yoke collector to max sine amplitude.. still no ou yet just tuning!
THEN turn on power fets to bang sine peaks. Using about 5uS slits and then you might get OU.
What!   ;D ;D can you explain that one ?
I will tell you, It will never work the way it is!  there is a reason why it doesn't work if you look at Adrian Gustors Tesla coil you might notice the L2 coil has about 12 to 24 turns on it
have you ever wondered why ? and you couldn't count the number of turns on the Tesla coil so why would that be ? And the L2 is one third from the bottom of the Tesla coil any idea's ?
And as well as that there is no where to store the current or the voltage now why would you want to do that ?
Solve all that then you might crack the problem.
If you were to sling the katcher out you could just wind a tuned coil and place it inside the grenade coil center and supply it with the HV at the resonant frequency and pulse it at a select low frequency.
AG
NickZ
   Apecore:   No, some parts have made it to Costa Rica, but now I need to make a long 4 hour trip to pick them up.I will be getting them this week, I hope, if all goes well.
   It has been a bit disappointing that no one is continuing to build and test this Akula/Ruslan type of device. Even Itsu has a hard time getting the pulse packets to work right. I don't know if I can do any better.
   Anything new with you. Staying out of the bars??? Or drinking alone...
AlienGrey
