0 Members and 111 Guests are viewing this topic.
NickZ
   Itsu:   The good news is that your shipment of parts just arrive at my door.
Very much appreciated. It came very well packaged, and in perfect shape.
   Now, back to this project.   Where was I... seams like a year went by, instead of a month or so.
itsu
Nick,
good to know, 6 weeks on its way!  :o
Itsu
stivep
bolt
im building soon half the stuff has arrived. Going to be using an arduino driving a 30Mhz DDS. So Tesla RF, phase control, push pull etc will all be in perfect sync. No wobbly katchers.
Ohh so exciting!
Bat1Robin2
I have arduino nano driving my push pull with fet drivers and have microsecond control of pulse width , using the internal timer to trigger the push pull. using Port B , and Port D command for faster control. max speed seems to be about 35 microseconds to do both push pull. I was using an external generator to signal the katcher that works and lights florescent bulbs above 200 khz. As far as the push pull it works better to do a push pull about every 100 microseconds.  pulse width works best at about 26 microseconds. The interesting thing tonight was the florescent bulb i have laying on my  top load was staying lit when i shut off the generator which like i said is being used to trigger the nano second pulse for the katcher!! and i was not  powering the push pull yoke only power is to the tesla(katcher) primary. After installing the capacitor i used before for best resonance the strangeness of the tesla self triggering itself started happening i could even pull out the generator input cord and lay it over the grenade to stabilize itself running along at some ridiculous high frequency i didn't measure yet but in the mhz. The watt meter was reading 41 watt input it idles around at 37 watt unloaded. No over unity just some strange self triggering in resonance i bet. So this arrangement can self trigger itself no need to even have a generated signal for the katcher except to jump start it, jusl lay the input wire near the topload and let it ring. Keep in mind you have to isolate the computer once arduino program loads or the katche/tesla frequecy works its way back into your computer and goofs with your usb devices making you restart your computer. Let it power down 10 seconds then plug into computer to update your program then pull usb back out to test again. Little bit of a hassle, but it appears arduino is capable and i have not killed it yet.
