0 Members and 627 Guests are viewing this topic.
Belfior
Quote from: AlienGrey on October 11, 2018, 12:08:51 PM
A similar machine by Thomas henry morey that got a patent with some interesting reading.
https://patentimages.storage.googleapis.com/19/81/34/1a05c66cb4c369/US2460707.pdf
Yes I think Moray acquired that patent to protect the tubes and valves he had in the "free energy" machine he tried to patent. Did not help much, since Bell labs patented the transistor after Moray made the mistake of telling his stuff to a Bell engineer.
Now if the Moray device is a "nuclear powered" device I don't want to go there. It seems what he had there is some kinda room temp fusion in a way. Not that hard to get radiation with little power. Gustave Le Bon did that with just light and a metal plate.
When they put a bulb between the antenna and the ground, the bulb did not light up. When the machine was between the antenna and ground the bulb did light. He could even cut the antenna cable and then put a plate of glass between the cut and the bulb still worked. People brought their own pieces of glass to the demos, since they thought he had tampered with the glass.
AlienGrey
Belfior
Quote from: AlienGrey on October 11, 2018, 02:21:34 PM
Thomas H Moray 'the sea pf energy in witch the earth floates.
http://www.free-energy-info.tuks.nl/P26.pdf
I have a copy and also other people's books that have researched him. He had like 27 stages in his machine and he said the energy comes in waves.
He had radioactive material in his detector and the other thing seemed to be like a diode. Engineers could not measure large energies between the antenna and the ground, but it did light up a light bulb.
So something was coming through the antenna and agitating the detector. Then a diode for rectifying that could explain the "waves" and some kinda "zener" to get the built up energy to the next stage. It seemed he started with a crystal radio setup and at some point he removed the front adjustable cap making it a high pass filter.
There are so many affidavits from engineers and physicists, that I don't doubt it worked.
Maybe he tapped into cosmic background radiation
AlienGrey
