0 Members and 629 Guests are viewing this topic.
Void
Hi Jeg. Ok, I thought your were still testing with V8Karlo's 'Q' circuit setup.
Your setup sounds interesting. :) All the best...
itsu
Quote from: Jeg on January 03, 2019, 10:56:19 AM
Itsu and all.
This is how it looks like when you return back a good portion of energy. Yellow is across my input capacitor. Purple is at the output.
Hi Jeg,
not sure what you mean by "the output", but i do not see any feedback ripply across by input cap.
Itsu
Jeg
Hi Itsu
My test with v8 q-topology wasn't successful as I said above. I take back just 100mA when my battery pushes 2Amps. So efficiency wasn't raised at all.
As I understood, V8karlos showed just a way and not a ready device as he explained.
Void
Quote from: Jeg on January 03, 2019, 05:09:11 PM
Hi Jeg. No, that is not correct. He said the following about his 'Q Device' circuit:
"Most of the output energy is returned to source."
"The Q device is simpler than Zero device and it has feedback which returns good
portion of energy to source while light bulb B1 at same time."
The implication apparently was that it should greatly improve efficiency over powering the bulb directly,
otherwise what would be the use of the circuit if it is less efficient than driving a bulb directly
at the same output power level?
V8Karlo mentions that there should be lots of spikes at the output of the coil,
so you may need to remove the snubber circuits on your PWM to replicate V8Karlo's
setup, but V8Karlo should be able to clarify about what he was doing to get those spikes.
AlienGrey
Quote from: Void on January 03, 2019, 06:00:05 PM
Well where is Karlo? it would be nice to hear his point of view
