0 Members and 196 Guests are viewing this topic.
color
Void:
The above picture is taken with Tesla not working.
Meanwell 24V-150W-6.3A, output about 42 ~ 45VAC(3A)
It is slightly better than the commercial inverter sold.
AlienGrey
Here we go everything is base 9 and 72 and 432 and 43200as based on pyramid versus earth mathematics but all base 9 the universe
https://www.youtube.com/watch?v=ODYy-ifTu1M
Color I will have to see what I can find I don't have a lot of space to juggle. and at best I only have the one based on 37.5meter 1/4 wave, however
my device looks very much like your black device which had a flat response over its useful spectrum, I did find that winding an inner coil
I could tune the device to match the Katcher 1/4 wave frequency but it did nothing to produce any gain at all.
I tend to think the magic happens in the Katcher or Tesla coil. If you don't have that then the rest is a waste of time! and we need to know where
the energy is coming from.
color
AlienGrey:
Your words were only half right, and the other half were not mentioned.
no,
Only 1/10 was mentioned and the remaining 9/10 was not mentioned.
In the Orient, there is a reincarnation.
Although reincarnation is similar to the resurrection, resurrection is born in the future, keeping all of the previous life intact, but reincarnation is born into another life.
Even if your kacher works perfectly,
If your generator is not suitable for a resurrection or reincarnation system, it will not work.
Without creating a resurrected generator system like Jesus
If you say no, I have nothing more to say.
You are not unlike many people who have completed 99% of the generators and have not built the rest of the 1% resurrection system.
You have to understand the resurrection system.
I can only tell you that the free generator is 100% live.
I have no ability to interpret my language in English.
I do not want to brag about the generator, nor do I have any idea.
Like anyone else, if you break hope, you do not even try to make a generator.
https://www.youtube.com/channel/UCnKiEDi9e3SyctFmLtczLBg/videos
https://yadi.sk/d/8rY1WiX6vZSnw
lightning, thunderbolt
https://2.bp.blogspot.com/-GkN3WYHkFqQ/XDZf23Jui3I/AAAAAAAAAxI/kPG1Ms894NUy79gFb-OpHkDfvNgz-nFbwCKgBGAs/s1600/%25ED%2598%25B886.gif
뇌격전류 평균크기 20ka
낙뢰 대지방전시간 약 1us
우리나라 낙뢰발생 평균은 28만/년개 이고 극성분포는 positive 34% negative 66%
뇌격전류평균은 19.85ka이고 최대값은 positive 1202ka negative 1657ka이다
벼락은 구름에 모인 전기의 극성에 따라 양전하 벼락과 음전하 벼락으로 구분된다.
이 중 90%가 음전하름 벼락이다. 보통 벼락의 최대 전류는 30,000 암페어 정도이며 전류가 흐르는 시간은 약 30 마이크로 초 정도이다.
일반적인 낙뢰가 구름이 음전하로 대전되고 지구로 방전되는 경우이다.
가장 일반적인 형태의 경우로 구름이 음으로 대전되고 지상으로 방전되는 경우의 예이다.
벼락은 보통 구름에서 시작되지만 땅에서 시작하기도 한다.
벼락 진행단계는
단계적 이끌이(stepped leader) -- 음 전하의 작은 덩어리로서 전류 저항이 작은 길을 따라 구름에서 땅으로 내려온다.
이 이끌이가 지나는 경로에 이온화된 기체의 흔적이 남는다. 이끌이는 그 동안 수십 cm의 길이와 마이크로 초 단위로
단계적으로 움직인다. 한 단계가 지나면 이끌이는 약 50 마이크로 초 동안 쉬었다가 다음 단계로 움직인다.
어떤 때는 이끌이의 전하 덩어리가 쪼개져 몇 개의 길이 생긴다.
이끌이가 땅에 가까이 오면 땅의 전자들이 밀려나고 양전하의 영역이 형성된다.
여기서 코로나 방전이 일어나서 접근하는 이끌이로 뻗는다. 내려오는 이끌이와 올라가는 코로나 방전이 연결되면,
구름과 지상 사이에 연속적인 길이 형성되어 강력한 되돌이 번개가 시작된다.
되돌이 번개 (return stroke)-- 되돌이 번개는 단계적 이끌이가 만들어 놓은 이온 흔적을 따라 근처의 전자를 빼앗으며
위로 빠르게 움직인다. 이 되돌이 번개가 구름 속으로 사라진 후에, 남은 전하의 양에 다라 벼락이 끝날 수도 있고
다시 재방전을 할수도 있다.
화살 이끌이(dart leader)-- 만일 구름 속에 충분한 전하가 있다면, 먼저 경로를 따라 화살 이끌이가 지상으로 내려올 수 있다.
그리고 이 화살 이끌이가 두 번째 되돌이 번개를 일으킨다.
하나의 벼락은 보통 서너 개의 되돌이 번개로 구성되며 되돌이 번개 사이의 간격은 대략 0.04-0.08 초다.
구름이 전기를 띄는 방법을 이론적으로 설명하는 것에는 두 가지 유력한 이론이 있다.
1. 대류 이론: 대기 중의 자유 이온들이 구름 속의 입자들에게 잡혀서 공기 흐름에 실려서 구름 속의 어떤 지역에 모인다.
2. 중력 이론: 음으로 대전된 입자들이 중력 때문에 더 가벼운 양으로 대전된 입자들과 분리된다.
https://www.youtube.com/watch?v=pgEtQdJdcl4&t=6s
https://www.youtube.com/watch?v=F_P90Q4fskE&t=20s
https://www.youtube.com/watch?v=6jZ5How6G8Q
He should eat his cheap shit.
This is the resurrection and reincarnation.
NickZ
   Color:   You were talking about Kapanadze, and his devices. But, you show the Stalker diagram and Cepren's devices.
They are not the same. At least Cepren is showing and explaining every bit of his replications. Kapanadze is not telling all. And after all this time, it's still not known just how TK's devices work. You will like all the others not be able to get a TK device replication to work.
   Adrian was able to replicate Cepren's device, and make it work.  Until...
   Below was my simple Kacher/induction circuit. It was the first Cepren self running device replication. Which only worked partially for me.  But, no OU, nor self running in my case,  so far.      NickZ
AlienGrey
Nick, we need to know the pulse width to drive  the push-pull toroid and phasing
and more than that driving the Katcher what is the pulse width with respect to
driver frequency that is critical as the width is also important!
Also in Color's artwork de drew a charge i'm sure to get that polarity using ac might be a problem in itself.
