0 Members and 208 Guests are viewing this topic.
AlienGrey
Quote from: Jeg on January 27, 2019, 03:40:52 AM
Hi guys
I remember once, Ruslan had stated that the magic happens on the yoke core and that he repeated the same trick at the output of grenade. Do you remember this statement? Does someone know how to locate it again? I think it was out of a translation of T1000 but not very sure.
No idea but if max TL494 is 200khz and Katcher is according to Ruslan 2Mhz if you divide that by 3 = 666khz666666   a bit of a devil then! anyway no way can you link 666khz with 200khz so what am I missing ?
color
AlienGrey:
if the grenade is a 37.5m 2mhz device then what frequency is the yoke and the TL494 push-pull running at ?
You ask the same question.
All work is done on a yoke transformer,
Grenades amplify.
Ruslan specifically mentions grenades because,
Grenades are not special,
It only exaggerates the principle amplified by the inductance.
There is no other reason.
Mhz is produced when TL494 and 74HC14 meet.
I do not have an oscilloscope and I upload a video.
https://www.youtube.com/watch?v=0SiXj_eK3oE
A special combination is required for Mhz to occur.
Ⓐ generates Mhz,
Ⓑ does not generate Mhz.
The reason you find it.
Push-Pull works with Khz,
Tesla kacher works with Mhz.
What is the 1/4 wavelength?
1.544 나누기 4는 386Khz ?
https://1.bp.blogspot.com/-c4GEWtOh3k4/XEv0VZUX6MI/AAAAAAAAA4I/kud6wPog57cIqagYV_pS3lXbDa17SoYDACKgBGAs/s1600/Standing_wave_2.gif
The Mhz Tesla kacher serves only as a pump to draw positive charges at ground,
When the amplified current is sent to the yoke transformer, push-pull resonance occurs and the grenade is amplified and sent to the lamp.
You are so dazzled by Mhz that only pumps,
Just ask how Mhz and Khz can combine.
magpwr:
hi color,
I forgotten to mention that the tesla circuit is operated independently.There is no synchronization with PWM circuit.Using stalker circuit ...
Nothing else to add.
Please let me know which schematic you use.
You do not have a free generator if the Tesla circuit works independently.
You must cooperate with Push-Pull.
In order to cooperate, each other must be connected.
I do not fully understand English.
This means that the amplified current of the diode bridge must be sent to the yoke transformer.
It does not mean that Mhz and Khz should combine.
magpwr
Quote from: color on January 27, 2019, 05:40:34 AM
AlienGrey:
Grenades amplify.
Ⓐ generates Mhz,
magpwr:
hi color,
hi color,
I am using Akula circuit only.The circuit which was also posted by you few days ago.I have also attached my circuit last year December in another FE topic in this site.
I am applying Divide by 3 as shown in Akula old video (out door demonstration without Earth) with waveform 55khz around 165khz for the smaller waveform as attached.
It will be impossible for you to work on any of this device without a scope and signal /basic pwm generator.
I don't believe in Ruslan circuit because he is using resonance which would means input frequency will be the same as output frequency.Even the Tesla coil can't influence the kapanadze output waveform  as tested.
That's all for this weekend.
NickZ
   Color:    The full bridge rectifier as shown in Ruslan's image, is connected to the output of the grenade. Which rectifies the AC to DC at the output, only.    The two diodes are used to connect the earth ground to the Kacher transistor emitter, only. They are not always needed. I don't use them.
   If the grenade is built to the proper specs, the output will be around 15KHz, or so. Or can be controlled to operate at that frequency, or close to it.
   If the simple Kacher circuit is built right, it will run at about at 1 to 2MHz. And can be tuned by adding or removing turns, and by adding ferrite to the core.  I do get a higher output when the simple Kacher is also running along with the induction circuit. And I get 5mm to 10mm streamers (arcs) from the grenade's antenna coil. So, anywhere from 5 to 10.000v.
   The idea is to build the proper controllable Kacher circuit, instead. Yet, those guys that have gone that route (itsu, Geg, Geofusion etz, have not shown any better output than what I have shown, and most of the time, even lower output than what I've obtained so far.
   If you think that there are errors in Stalkers diagrams,  I don't agree, and I have built that set up. Using his previous simple Kacher and grenade/induction circuit.
   You don't really need an oscilloscope to tune the device. Geo did quite well even without using one. Of course it's always better to use one, but it's not entirely needed to tune with.   If you guys think that there is some special frequency match, like 1/4, 1/3, 1/2, etz,  please proof the point. As I have not actually seen that to be the case.
   The image below is running on only an 18v input, to light the three 200w bulbs. It is even brighter at 24v or higher input, which is what I'm using now.   The full bridge rectifier is next to the right side of the grenade coil.  Although there was no feed back circuit used at that time, I do have that set up now.
color
magpwr:
hi color,
May I ask you to republish the circuit of Akura?
It is your heart to believe in any circuit and not believe it.
NickZ:
I want Geo to come back.
And I hope you understand the core principles of free generators.
I'll ask NickZ.
Where do you think Tesla Catcher should be connected?
Please link and post it.
If you do not understand this, all the questions are useless.
And,
It explains why the frequency waveform of magpwr is ordinary.
