0 Members and 410 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on February 05, 2019, 11:09:58 AM
Hi steadyfield,
What happens if you disconnect the gate to one of the push-pull mosfets. Do you notice an increased 'effect', a term we used way back to describe an increased brightness of the output bulb to hand movements around the grenade?
Is it a 'Theremin' from 1951 day the earth stood still ?  'Klaatu barada nikto'. ;D
https://www.youtube.com/watch?v=5VQgImg15sQ
Ah! the patent money greed is comming out of the wood work.
saturnio
Quote from: Jeg on February 05, 2019, 10:20:45 AM
It is unipolar because battery conducts only in one direction. You see a sinus wave because secondary is oscillating in voltage. Take for example a simple primary and secondary. When current flows along the primary, you also see a current flowing in one direction across secondary.
Hi Jeg, I'm a passive forum user, some times I make some comments. I belive that current is also a sine waveform, becouse it is a resonating second order system. I measured in my tesla coil for trigger a push-pull its primary system. For me is a mystery those pulses in those schematics
1) Could someone explain for what is used the ferrite mentioned in last posts? I know that wound and counter wound ferrites are used in RF to add a little resistance. I saw a resistor added between tesla coil and capacitor in this paper https://www.researchgate.net/publication/318036034_Quarter_wavelength_resonators_for_use_in_wireless_capacitive_power_transfer .(Also they used a thermal camera to know if the coil is resonating in 1/4 or not, very intresting)
2) Does anyone could explain me for what is used the inductor? and at what frequency should resonate?
Thank you
NickZ
   Although I may be wrong, as it's been a while since my last tests. But, I think that the inductor is working at the same frequency as the grenade coil.  If I'm not mistaken. As the running frequency sent by the push pull circuit to both coils, seams to be the same for both the inductor, as well as the grenade's output coil frequency.  Just how it works, or what it's purpose is, and what it does exactly, is not totally known to me.
  I try to follow the schematics to learn more about the workings of the whole device. I'm just a simple experimenter, not the designer of the circuit.  Sorry.  Perhaps someone else can answer your questions better. In any case those are my thoughts about that.   As far as the ferrite rod, and it's counter wound windings, what I see is that it does intensify the spark at the antenna coil, and helps a bit.
Jeg
Quote from: saturnio on February 05, 2019, 09:53:08 PM
1
Hi Saturnio. Welcome to Ruslan craziness ;)
You are very right my friend. Too much thinking some times... I would block it with a diode between grenade and ground. This way you secure for sure one way direction flowing.
stivep
