0 Members and 388 Guests are viewing this topic.
NickZ
   That was one of his first design builds, back in 2014. 5 years old. When he was trying out this and that.
   Don't waste your time. That may have been one of the ones that didn't work, or was faked. No way of really knowing.
   That is NOT how the device is built, or works now. But, of course it's up to you if you think that is the way to go.
    I would not follow that system.
NickZ
Quote from: justawatt on February 11, 2019, 12:29:00 PM
Hi geo good to see you.
I want one help from you I will share one video it's not clear.
I will post the circuit here.
Basically what he have done is the output coil is shorted and
Load is connected with shorted coil and ground.
Can you short the out put coil of Ruslan winding you have
And connect load with ground.
https://m.youtube.com/watch?v=lwRPRiOyyss
   Justawatt:  That is NOT a free energy generator. No feed back path, nor extra energy output.
   You can connect a bulb directly to the grid positive, and to a bulb, then to an earth ground, it will work. No OU, or self running though.
Jeg
I wonder if Ruslan has a mosfet switch at his grenade output. I mean, perhaps the answer is something silly like that. Charging effectively a capacitor for 10ms and then discharging it over the load for the next 10ms. Total 20ms / 50Hz. Until now we have discovered 1001 ways for increasing efficiency and bemf spikes. But when a load is connected continually across the output then everything is diminishing. Perhaps the gain is in charging dielectrics but disconnected of loads, with sharp high frequency currents of high potential and that is all.
NickZ
   Jeg:   The device should be tuned while the load is also connected. And, the feed back path, also.  Otherwise, it will all have to be tuned again. As the feed back path presents quite a load, as well, and can take a good part of the output to run it.
    My feelings are that the main point of failure is the tiny bandwidth of working frequencies between the induction circuit and the Kacher. Just a little off, and there is no real effect.    If the 37.5 to 40 meter earth ground makes no difference, then the working frequencies are OFF.  And being just a little off, you see no "effect", or very little.  It's the EXACT frequency match that counts the most, or the caps, output rectifiers, and earth ground lines, etz,  aren't doing what they should be doing.  You can build controllable Kacher circuits, but if the Kacher/Tesla secondary coil is not pre tuned to the proper frequency to start with, the frequency and dead time controls on the Kacher circuit aren't able to make up for it.
The Kacher secondary coil self running frequency should be tuned before hand, to a self resonant frequency that will sync with the grenade coils. Such as a Kacher secondary self running frequency of 1.5MHz. Then later fine tune that frequency output signal, using the Kacher's controllers.
AlienGrey
