0 Members and 91 Guests are viewing this topic.
color
T-1000:
March 15, 2016, 04:24:06 PM »
Quote from: wattsup on March 15, 2016, 03:22:09 PM
Sooooooooooooooooooooooo. Is it possible to marry the best attributes of both AC and DC into one method?
Without making another wall of text just put DC + wire + bulb as simple circuit then apply AC over capacitor connected to one of DC terminals connected to the bulb and the end of same wire going to the bulb. Then see what will happen.
Then later exchange that piece of wire with a coil.
And no theory can exactly will tell how both currents will be going over same wire... ;)
Cheers!
When the T-1000 went out with Wesley, he became more and more like Wesley.
Do not touch too much .... Wesley ...
It is time for us all to remain.
You want to keep your own contradictions without believing in free generators.
color
Zeitmaschine:
March 22, 2016, 11:20:25 AM »
Quote from: pix on March 21, 2016, 10:42:31 PM
By who???
Could you be more specific?
First, by people who fall eagerly for Kapanadze's eye candys again and again. >:(
Second, by people who write up to four posts in a consecutive row (although this forum has an edit function) in order to stretch the length of this thread unnecessarily and hence make it more difficult to find anything written just a few days ago.
So as it seems I have to quote myself form the long ago buried PAGE 977:
He makes the same mistake as Kapanadze did with his phony spark setup: If the energy output consumed by the lamps is ever in relation to the spark then the lamps have to flicker because the spark flickers. If the lamps are glowing steady then the current that goes through the lamps cannot be related to the spark in any way. Simple as that.
And this still means there is no spark gap that contributes anything to the energy output of the Kapanadze device, especially a spark gap that does not fire at all.
Actually I'm more and more attracted by the idea to open a new thread about a summarization what we know (for sure) regarding the Kapanadze and Stepanov devices, so there is no need to go in circles time and time again.
Quote from: pix on March 21, 2016, 10:51:41 PM
Meta,
Please stop with this negentropy 4th dimension stuff.
Why should he? If someone here comes too close to Kapanadze's principle of work then why not bury it quickly by means of the 4th dimension? ;D ::)
tysb3
@color
you are flooding this forum. you are troll.
AlienGrey
Quote from: tysb3 on February 17, 2019, 01:51:25 PM
@color
TYSB3 I note your comment from the dark side, However, without Color, we would have not have cleared up multiple definitions, sometimes I wonder where some you guys get such negativity from as you apear to have a self distructive of positive useful information.
AlienGrey
Quote from: T-1000 on February 15, 2019, 11:04:56 AM
Hi all,
It is been a while since my last post... Well, lets hit RESET button :)
Over last 20 forum pages I've seen lots of off-topic and steering away posts. Well, people here can be easily distracted as it always was..
With nice come back videos from Geo  there are some ideas to add in experiments. When you see YELLOW arcs from grenade wires after stepping up VOLTAGE on Tesla primary (that is critical part!) the only one thing remains. The post #20519 almost had it in picture, except missing 2 HV capacitors in series on each wire PRIOR to diode bridge(no EARTH GROUND contact at that point!). And those caps have to make grenade sing ("Radio Moscow") and not not just a yoke. The real power there is in virtual CAPACITOR plates on grenade which are key for collecting particles from highly ionised air. Which is driven by disruptive Tesla coil for causing required effects. If you guys will get to that stage, interesting things should happen.
Hopefully that can kick in another series of experiments.
Good luck!
T-1000
Re grenade circuit winding, the way this coil is wound is like nothing I have ever seen, as each winding cancels the other out, wouldn't the one testing device it would give no output.
