0 Members and 57 Guests are viewing this topic.
AlienGrey
Jeg I had a problem with trying to synchronize Sergeys 1.5mhz Katcha with 15khz grenade inductor  circuit
one way to do it with logic is use a 3mhz divide by 2 for Katcher and for grenade divide the 3mhz by 10 and 10
=30 kHz then divide by 2 for 50/50 then inject it into a 494 to produce push-pull, then everything is locked to the 3mhz VFO note a bit of other logic might be needed for gating but simple to do.
A bit like your waveform you were asking about.
Note in the Sergey circuit I included a current limit circuit so as not to kill the Katcher driver and output transistor too quick
NickZ
Quote from: AlienGrey on March 16, 2019, 05:34:41 AM
rewind it with the fishing twine in between layers works in highering the frequency but I always save my old one just encase.
   I've already have done that a couple of years or so ago.
   The purpose of the fishing line is to be able to have more capacitance when using a shorter secondary coil for the Kacher.
Although that part of it does work, there is no need to do that when the 1 to 2MHz can be reached by the normal secondary windings. It's used by guys that want to be able to reach something like 3MHz or higher, but find that their Kacher has only a tiny output at that frequency when using the normally wound (shorter) secondary coil. So, the fishing line is used, but it's not really needed, at all. Nor has it been used by Akula, Ruslan, nor Stalker.
   AG, again, why don't you try your suggestions, first, and show how well it works to produce a self runner before handing out advice.
NickZ
   What we know about Akula is that he like Ruslan and Stalker, they are not going to show any more self runners on video.
   Stalker shows how to make the circuits, but not how well they self run. As that is the dangerous part of any demonstration.   Ruslan shows his newer already built systems self running, but not how they are made and connected up, nor the schematics.    Stalker shows how to build his circuits with full schematics or diagrams, but, not how well they worked to self run.      And finally, Akula is MIA.  Nor has he shown any brand new Mercedes parked in his drive way.
AlienGrey
Ha Ha are you trying to get me bumped off  ;D ;D you already explained why!
https://www.youtube.com/watch?time_continue=27&v=4iKDvfZzFt8
I don't understand the higher capacitance increase with the fishing wire bit you got I get the opposite effect in fact
with a 10m Katcher, I got over 5mhz with 1mm wire lowering the wire diameter reduces the frequency and at the same time
with that short length, you won't find it at all easy getting it to self oscillate without other means of gain or direct drive from
my experiments so how did Adrian Gustove get such huge sparks with his setup?
Nick, you know your self this game is full of pitfalls and missing vital information so just stick with it and see how things go.
A Katcher tunned to 1.5mhz with caps making up a tank circuit
Jeg
AG
Yes locking frequencies is a more professional approach. It is just that when someone sees devices like Roma's or Maxim's, wonders about the necessity of such complex arrangements especially when still the basic idea is not well established. But your build for sure will help you a lot when everything will be in the right order. ;)
Nick
It is the other way around. With fishing line we reduce inter capacity when it needs for the right tuning. I think magpwr before few years, mentioned that the PVC tubes add more capacity to the coil than what we think and the net result is that we are not able to tune by just calculating wire length.
