0 Members and 1021 Guests are viewing this topic.
Sergh
Quote from: NickZ on March 16, 2019, 03:27:56 PM
   You mean that this double frequency effect won't show up on my scope connected at the bulbs?    Perhaps, you can show where this happens. As I have  not seen anything like that. And, I dont have a spetrum analyzer.
Not frequency doubling, but multiplication.
And in general, what is "frequency"?
1. Spectral density
https://en.wikipedia.org/wiki/Spectral_density
2. Fourier transform
https://en.wikipedia.org/wiki/Fourier_transform
...very deep:Stochastic resonance
https://en.wikipedia.org/wiki/Stochastic_resonance
NickZ
Quote from: conico on March 16, 2019, 03:34:00 PM
Yes NickZ , You have 600nf-900nf caps  for grenade resonance? Put just 100nf and you will see the double of frequency.
That why my grenade coil was not at resonance i had just 100nf on it and it not was at resonance. And because grenade was not at resonance i had just 70-80V on the bulbs at load.
   conico:  I am using a 0.1uf at the grenade output coil for parallel resonance. Ruslan uses 2, 0.15uf.
   As these wima caps can get hot, mine cracked, and other cheaper caps that were not the wima caps can burn up, as there is a bit of current there.
   I also use a couple of the black AC fan caps about 3uf each to filter with, after my full bridge rectifier, but before the bulbs, also.
   What voltage do you have now at your bulbs?
NickZ
Quote from: Jeg on March 16, 2019, 12:09:40 PM
Hi Nick.
Difficult to see what is behind Roma's circuit. Looks simple but is it really? I have already prepared some things to test on this direction. Nothing is easy but we never surrender right? :D
   Jeg:
   Right!
   It all worth doing in any case. Nothing to lose but some time, and everything to win if it works as has shown.   But, I think that knowing the right and exact turn counts of all the coils and their former tubes size and other important details are some of the main things to know beforehand. As there is no controller, nor can it be adjusted, other that by caps for resonance, in that circuit.   Let us know how it goes,  one way or the other.  Good luck.
   Makes me wonder what happened with that circuit, and it's inventor.
Void
Hi Conico, You mentioned previously that connecting your earth ground doesn't make much difference,
maybe just a small difference. That would still seem to indicate that something is still not right in your
setup/tuning, or maybe these type of devices can only work in very select locations around the globe. :)
AlienGrey
Quote from: NickZ on March 16, 2019, 07:06:37 PM
   Jeg:
   Right!
Hi is this the everlasting eternal touch?  I made that and a PCB for it, it didn't work nor did the Akula one, surprise surprise !
there was another version of it the Germon Guy Arthur bought it later on after I had binned it or it got lost.
but i found some Russian info on it there is a thread on here about it TinselKoala's name comes to mind talk to him.
Also Delomorto look under his name too
