0 Members and 389 Guests are viewing this topic.
Vasiliy Buslaev
Quote from: d3x0r on October 02, 2012, 10:31:48 PM
For T-1000 or any other russian... can you explain the following translation?
Of the gene on human trafficking....
Of the gene on human trafficking to the coil which voltage-150V? And gene-150 postoyanke?
ОÑ, ген на ТЛ на каÑ,ушку какое напряжение-150в?И на ген-150 посÑ,оянка?
Reh(ген) is short for General?  it's Gen?  is that Generator?  I see the short ген a lot.
human trafficing I guess is 'slaves to'?
Aidas, now you are Russian :) :) :), congratulations on the promotion. :) :) :)
Ignore the trolls (Ganzha) and work quietly. Good luck! 8)
to d3x0r. GEN - is Russian slang Electrotechnical is short for - generator. GEN - Generator ( Ð"ЕН - генераÑ,ор)
to the generals no relation. :)
посÑ,оянка - it's direct current
"ОÑ, ген на ТЛ на каÑ,ушку какое напряжение-150в?И на ген-150 посÑ,оянка?" - it's = "from a generator on ТЛ (TL494) on the coil how much voltage - 150 volts? and on genernator - 150 volts DC?"
Regards to all
Vasiliy
verpies
Quote from: Vasiliy Buslaev on October 03, 2012, 03:58:13 AM
P.S. However, you skeptic towards work Dally. :) :(
I cannot decide at this point in time.
I agree with Hoppy the the ratio of turns between L1 and L4 is incapable of producing sufficient voltage to tun the ATX PSU if power to L4 originates only from L1.
However if it doesn't (e.g. there is some kind of unconventional process between L1 and L4) then anything is possible.
One thing about Dally's contraption that seems wrong to me, is the lack of any Gain Media (e.g. ferrite or brass core).
Vasiliy Buslaev
Quote from: Hoppy on October 03, 2012, 04:05:35 AM
With regards to the nano pulser element of the circuit, is there something special about the KD203 diode (700V / 10A), which precludes substitution? It looks like a standard type of rectifier to me, please correct me if I'm wrong.
With a good spec for the green transformer, between us, we should be able to replicate accurately.
Hoppy
Yes, this is a standard rectifier diode, the old type.
KÐ"203, KÐ"204, and many others can be used, it is necessary to try.
Vasiliy Buslaev
Quote from: verpies on October 03, 2012, 04:42:28 AM
Yes, it is a small mistake, and therefore output power is low.
General construction Dally - is essentially a design not Kapanadze, is a construct of our compatriot: nick "SR" (Sresearcher). He did a unit  for 150-watt  lamp. If you remember, even Patrick Kelly mixed up it with Dynatron.
SR used a core of ferrite rings
Vasiliy
Frederic2k1
What actually happens when you can douple the amplitude of a wave via superimposition of a reflected wave ?
Is the power not 4 times the initial wave ?
You send two waves into it and the output is double these two waves...
I know that Jdo300 tried to replicate exactly this in the times of steven marks tpu replication going on...
see here: [size=78%]http://www.youtube.com/watch?v=OqwPMAJsh3I[/size]
