0 Members and 502 Guests are viewing this topic.
Jeg
Quote from: r2fpl on March 30, 2019, 06:16:25 AM
https://www.youtube.com/watch?v=nkMndCsNRQU
Cool guys thanks a lot.
R2fpl, i wonder what kind of led is this and how it is hooked. I found a small 220V orange led taken out of a heating boyler. I hope it can do the job.
NickZ
    Jeg:    I use a small neon bulb soldered to an AV plug. These neon bulbs can be bought for use in AC line testing at any hardware store.
I also use a single led onto an AV plug. As well as an led connected onto a small inductor, as is shown in some of my videos.
   I looked at your last Kacher/Grenade video, to see what kind of signal you were getting. It looks like your Kacher secondary is too long to effectively sync with the grenade coils, and you were not using an antenna coil or ferrite bar.  The Kacher fires at the right time, although your grenade seams to fire in the negative cycle. But what does it actually do to the interaction, when using a bigger load, as you didn't show the output to the bulbs, on the video.   I'm not looking to make any critical comments, just looking for the cause of the poor performance and interaction.
   Again, below is one of Stalkers scope shots showing what his signals look like. As you can see, his Kacher is firing on the valley of the sine wave, not at the beginning of it. Maybe this is important, that I don't know. But, Itsu was not able to replicate that particular signal sync.
Jeg
Hi Nick
You have seen a relatively old video. I never recorded all of my experiments with Ruslan. When I found a dead end, i turned my focus to smaller devices with which I can use my oscilloscope without worries.
You know there are many issues that has to be considered individually. One of them is ''grounding''. We have two references. One is the system's ground, and the other is the earth ground.
How you deal with this? At the attached image does anyone know what this output line filter looks like? What ruslan uses there?
AlienGrey
You have a conundrum  ;D so how would you tackle that? well I would start with the 37.5 m of wire
find it's wavelength and ignore the other BS that's on it to confuse I think you will find it's about 8mhz
that circuit might have a lot of bugs to iron out to get to where his idea is !
I'm not saying anything will come of it I'm just from a ham radio background.
AlienGrey
Quote from: NickZ on March 30, 2019, 10:04:57 AM
It looks like someone is just playing in that scope shot, is what are the signals exactly? but then i haven't got that far
but what is synced with what >? can you try and expand those narrow pulses out to see if they are in sync with anything?
