0 Members and 809 Guests are viewing this topic.
T-1000
Quote from: NickZ on May 10, 2019, 11:42:13 AM
I think that may be where we are all stuck at. Trying to compensate for an improper match, to begin with.
Or put little coil around ground cable + scope and start spiking grenade all way up until it will start showing most current going to/from the ground...
P.S> The SWR meter probably would be good indicator there as well.
AlienGrey
  T-1000:   In my humble opinion... If the Kacher secondary coil does not free run at the exact proper frequency to begin with, the controllable Kacher circuit will NOT make up for it, by readjusting the off frequency to the correct match. No matter how you turn the trim pots. The results are little to no gain or just a small gain, but still no OU, nor the ability to self run. And showing NO GAIN above 500 plus watts loads. I think that may be where we are all stuck at. Trying to compensate for an improper match, to begin with.  We need to know the exact wire sizes of all the coils.
if your Katcher is generating AC how does it do anything static electricity is not ac Ruslan uses an inverted LOPT coil and spark plug in his video it's all designed to not work.
apecore
Quote from: T-1000 on May 10, 2019, 11:31:19 AM
Just a bit of refreshing memory - in https://img0.liveinternet.ru/images/attach/c/6/91/684/91684490_large_100_6334.JPG and https://img1.liveinternet.ru/images/attach/c/6/91/684/91684491_large_100_6335.JPG Dally did not have katcher nor fancy PLLs. Only narrow pulse was going into coax cable between 2 windings and still making same power amplification result.
So what everyone is missing?
T-1000,
Good observation.
Unipolair pulsing... thats the key i guess.....
Our current kacher systems only transmit some energy to the grenade/ inductor at this moment,..  either it is a a kacher without or with interrupter
When we can create unpolair pulses.. . either with Dally system or with tesla system it will be Bahama time..
So this makes me come back to the latest vid from Ruslan k,..  his system does not Lock on kacher frequenty.. or have any fancy electronics to create the unipolair pulsing... (if somebody thinks otherwise.... please give a reply)
Does this means that resonance at the kacher system is not important?......  is he using only his 4046 for fixed frequenty pulsing?
If this is true only standing wave matters related to wire length
With respect to the statements from older related Ruslan vids the next items do come to the surface everytime....
Disruptive and Ground eating...  these two items only go together when the puls is unipolair.
Greetings
apecore
Quote from: T-1000 on May 10, 2019, 11:55:33 AM
very good suggestion..
NickZ
   Guys:
   I would like to see a test showing any real power at all, coming from the ground line. As I doubt it. Going to the ground, yes.    Nor do I see any unipolar pulses, on any of the self running videos. If so, please post a link to it, showing how that looks on a scope. As all I've ever seen anywhere are sine waves coming off of the HV circuit, at the antenna coil. So, please show otherwise, if possible.
   Akula has shown that even without a ground line his second self runner would still run, although not as well, with some overheating. So in that case there is NO power is coming from the ground. So, where does it come from?
The surrounding ambient, perhaps, as Tesla has stated. I doubt that he would have talked about tapping "free electrons", but mentioned the Aether, instead. Maybe there is more to this, than just ionizing the air, and catching free electrons.
   PS. Itsu, good to see you still checking in on us.
