0 Members and 198 Guests are viewing this topic.
T-1000
Quote from: AlienGrey on May 15, 2019, 10:34:16 AM
HI Arunus, Well the lower layer would be the live side or end and the outside would be earthy side.
AG
Just sticking inductor between 2 layers of grenade would be OK. And making sure the outer layer of inductor is more close to "antenna" than ground connection.
So the 2nd longest grenade coil layer would end up on top of inductor and most close to "antenna".
AlienGrey
Quote from: soliman on May 15, 2019, 08:34:22 AM
Hi. Jeg
I'm working on this circuit, this looks promising
to be able to see the wave of the fish.
I notice in your circuit your showing the 494 as it is being fed into the input of the LT494 auxiliary input which is interesting as I tried that with a logic input what I noticed was it uses an internal 'D'type what I have to ask is what difference does that make when the 494 squares it up, but when it goes into an inductor like the yoke it turns it into a sine wave if you tune it. There is another problem though the LF that should be interesting to experiment with and its characteristics involved. I will have to study your circuit it's a bit big to get on the screen all at once. Anyway good luck
PS a great film you posted hadn't seen that one.
T-1000
Hi all,
Just a few side notes after spending more than 2 hours on watching of Sergej Panov videos. Hopefully that will be useful.
His fake "replication" of Ruslan Kulabuxov was based on hidden 220V phase wire going to relay under begining of ground cable - https://youtu.be/Gy5za1r5gCw?t=1591
Which might be true about Ruslan Kulabuxov case (see markings on ground wire beginings with "bumps" on one side and why they are not over all ground cable) but still.. It does not mean there are no real devices.  And for strong reference to real devices there is really old N. Tesla quote about stray frequency discharging low frequency current on explosive rate.. Which may be used on intent between ground/air potential difference (ref to one of many articles about it - http://www.tfcbooks.com/articles/tunguska.htm )  So in short it is up to everyone for finding a way to convert ambient energy around us into useful form if you still do not give up on cases such I just described above...
Cheers!
Jeg
Hi. Jeg
Hi soliman
In my opinion, the ''fish'' like waveform is a product of standing waves which appear across the length of the coil, but we need some special conditions to create first. As i understood from Stalker and others we need:
1. The right length of wire for each of the six grenade layers
2. Folding of the wire to the right points
3. The right duty cycle
4. The right power input at the right frequency (There is a threshold here which we need to exceed. Don't expect anything to see under this threshold.)
NickZ
   Jeg:   Agreed.  The explanation and diagrams from Stalker are the most clear and well documented of all the self running devices.   Again, here is the Stalker fish wave form, below. But, even itsu could not get it to fire at the valley of the sine wave.
