0 Members and 557 Guests are viewing this topic.
magpwr
hi everyone,
Few years ago i recall someone mentioned in this topic or another about how fast capacitor can be charged up or charging the capacitor bank related to kapanadze.
Using Nelson circuit HV capacitor are charge up without causing a brief over current on the source.Because i did a short circuit test at the transformer output and transformer input and found that there was no increase in current drawn.I found that the Line filter using green toroid was still oscillating.This is different from disposable camera circuit which the current drawn from 1XAAA battery is higher while flash capacitor is being charged up.Not forgetting there was no damage to capacitor for disposable camera once peak voltage is reached since capacitor rated/leakage current will match the rectified tiny transformer output.
Why i am interested because large circut can be started by mere 9volts battery.How it is kept running is a different ball game altogether.
Nelson circuit was provided for public in his video without playing video.https://www.youtube.com/watch?v=TjK6OlYO9Aw
endlessoceans
Quote from: magpwr on May 28, 2019, 08:06:30 AM
hi everyone,
Circuits that run close to 100% efficiency have the appearance of OU.  They can run heavy inductive loads and be tned in a way so as to not cripple the source.
Kapanadze starts the device with a 9 volt battery as a typical sleight of hand to detract from the larger hidden LIPO battery.
All the others like Ruslan are known scammers
magpwr
Quote from: endlessoceans on May 28, 2019, 08:21:37 AM
hi endlessoceans,
I am aware Ruslan was a faked long time ago.But we did get idea from Ruslan kapanadze coil.
The circuit which i have posted couple of months ago is a variant of Akula where 10khz IGBT drive combine with Tesla coil circuit also provided can produce 30khz but can achieve around 80khz sine wave at kapandze output.
But i suspect Akula is not using 3 turns to obtain high voltage but he might be using 28turns to achieve this feat.If large toroid is running on dc 200volts the 28turns from large toroid will create around 2kv high current.Safety. This setup i have not attempt yet since i don't know what to do with the 3 turns which will produce around 240Vpp.I need to gather all infos before i can execute this final experiment since i ran out of luck/patience the last round.
T-1000
Quote from: magpwr on May 28, 2019, 08:34:37 AM
Hi Chet,
That is correct, akula had 30/45/60V outputs from the "28T" part of yoke. After rectifying and filtering it was going to Tesla coil driver - https://overunity.com/14734/akula-1-kwatt-free-energy-generator/msg408288/#msg408288
Just again, in early akula's video he also shared information about finding resonance to the ground. Which is supposed part of external energy source open circuit for amplifying current on grenade coil inductor.
Cheers!
WhatIsIt
You all connect Ruslan design to Kapanadze design?
Why?
They both has OU, but what else in common?
You don't know about Kapanadze frequency, number of coils or input voltage, sine or pulse DC?
NOTHING!
So, why is Ruslan device similar to Kapanadze?
Kapanadze and Ruslan do not look even similar on pictures?
What is your connection between two guys and theirs devices?
