0 Members and 468 Guests are viewing this topic.
apecore
Hi all,
Did some perhaps Geo.. connected the Gate and  L2 to ground already?... does it work?
Nick,  use a torroid for the CT... it is able to detect the Mhz range as i am using it for the PLL-DRSSTC also... (measuring the current from the L2 which is connected to ground also.
NickZ
Quote from: apecore on June 24, 2019, 01:18:55 PM
Hi all,
   apecore:  Ok, but what torroid did you use. Color, size, coils, etz...   I did make a previous video showing the CT on a torroid core, but I did not see MHz pulses. It did not have a resistor on it, at the time. I'll put a resistor on it and try it again on the ground line, as well as on the 3t coil circuit. But, like I said, if I connect the scope's negative probe to see the voltages, or currents, it kills and grounds any effect coming from the Kacher's HV output.
apecore
Quote from: NickZ on June 24, 2019, 01:38:47 PM
One inch green.... windings f.i. 30...  put always a resistor  47 ohm..(not critical) but probe across the resistor.
GeoFusion
Hi all,
Nick,
The current transformer that will.go over the ground
line needs to be like a toroid and making it from plastic
Not ferrite. See image of example.
The L2 of kacher's needs to be grounded with the ground
To see results. See image.
Reminder that we all are searching for that power coming in back.
Cheers
NickZ
   Geo:   Where does the idea come from that a plastic torroid is what is needed on the ground line? Did T-1000 test this idea himself, or is there some device showing what the signals should look like using a plastic core?
   Both Ruslan and Stalker have used ferrite torroids, on the 3t coil circuit. Not on the ground line.
   Where am I going to find a plastic torroid former???
