0 Members and 113 Guests are viewing this topic.
MenofFather
Quote from: magpwr on August 21, 2013, 08:02:15 PM
Hi T-1000,Grumage,menofather,bringdownthezog and everyone else,
I have mentioned to bringdownthezog around 1 week after he posted,that i have replicated this circuit which i called it Kapanadze mini with success with ou but without load.If even try to put 1w bulb or even 1k resistor at output.The voltage will drop.Please see attachment.The circuit is running in milisec.
The reason why there is ou is because i find that my function generator was supply the power somehow then i intentionally put 1k resistor to transistor.It did slow the voltage going upwards.
Yes i kill many hours trying to optimize the efficiency to the max by swapping out many components in circuit.
I hope this will stop you guys from wasting more time.Please.This circuit is a good concept but not a ou device.I would not waste my time on this circuit for ou maybe use as idea for joule thief that's all.
Please observe in attached video.I connect and disconnect the switch at the left side and watch mulitmeter show rise in voltage.
Seems Grumage good make to remove this diode, because in video, there men speaking with Pantiuchov, author of this divice, in it schematic in laptop seems this diode not exist.
MenofFather
And in you schematic in video is eror. Not 50 uH writen, but 50 turns. From were you get 50 uH? ;D  But maybe it have and 50 uH, I dont know, that exatly it inductance. It 50 turns on two ferite rings of 2.2 cm diameter and 0.6 cm hight.
MenofFather
And you joking? If you test only with simulator, then it wery stenght, because simulator can show not true, because  it based on fisics, that not agree that you can get overunity.
magpwr
Quote from: MenofFather on August 22, 2013, 12:27:34 AM
Hi MenoFather,
If you take a look at  my previous posting to bringdownthezog around 2 or 3 weeks.
I told him this is not a overunity device.Because in real life there are losses in component transformer and etc.
But no one is convinced what i said so i merely used video capture merely to show that i have already done this quick experiment  at that time.
The reason why i choose to start on this circuit weeks back because to me the concept seems logical it will work.
Yes it did work only in simulation with no load.But again in stimulation once you put load it's not ou.
I have already tried to convince others that this device is fake but people are still discussing about it.But then again i should not be stopping the rest since i merely report my findings on as is basis.
magpwr
Quote from: MenofFather on August 22, 2013, 12:18:48 AM
Hi,
Yes i had problem understanding foreign language as shown in circuit symbol.But this device is fake anyway or anyhow on how you swap the component with different value.
But i won't stop anyone else to try it out.
