0 Members and 189 Guests are viewing this topic.
soliman
Quote from: AlienGrey on June 21, 2020, 08:23:44 AM
My advice to you is to build a proper katcher driver and use a 50R imedance driver or better still use a PNP and a NPN common emitter driver and use 12 volt logic or rail shift circuit or if your using TTL HC use a Mos Fet driver it not worth the hassel faffing around!
and what is the wave form like your driving ir with ?
AG
No, AG.
In these cases the output voltage depends on the input voltage, not on the supply voltage. I did this and I can verify that this is so.
AlienGrey
can you show me what the wave form is like your driving the Tesla Katcher coil with ?
Show me, draw it if you must.
SolarLab
F. Y. I.
More (probably useless and boring) theory, including the underlying experiments and mathematics!
Энергетика фазового сдвига тока в катушке индуктивности
[Power phase shift current in the inductor]
https://gorchilin.com/articles/math/phase_shift
Note: © Reprinting of materials is possible subject to the installation of links to it and copyright
Quotes translated from the above "Gorchilin presentations:"
"As you can see from the last formula, if α=0, i.e. the phase shift is not present, and the increase in efficiency cannot exceed one. But let's consider the cases when the phase shift is. - "
"The first thing you can immediately notice if the value of the angle of phase shift is insufficient, the desired effect is not achieved. The following graph (Fig. 2) dependences of the efficiency gains from the phase angle α and the coefficient of variation of the resonance Δ (KOR). Here you can see that if α=0 (red graph), the growth efficiency is always less than unity. When you increase the shear angle, after a certain value, the increase is beyond a single value, which could mean, in practice, the appearance of the desired effect. In this case, this occurs when α>0.25. For example, a crimson dotted curve in α=0.4, reaches maximum values of 1.8."
"Second, the graph shows that the maximum gain is not exactly in resonance, and slightly above it. You can check that if the shear angle is negative, then this maximum will be located below the resonance. This was observed in the experiment."
Having been censored and banned, etc., on this and other forums, does not mean our development has ceased - Quite the contrary in fact!
Have a great weekend...
SL
soliman
Quote from: AlienGrey on June 21, 2020, 10:06:45 AM
it is the circuit that I am testing.
AlienGrey
