0 Members and 348 Guests are viewing this topic.
AlienGrey
conico did you build the Tesla coil Enjoykin modulator circuit and are you using it in your setup
Also have a look here they got rid of this guy but he had a lot to show us, his circuits are important
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/30/
NickZ
    conico:
   Ruslan does say which cap to use for the parallel circuit. He mentioned in another earlier video that it should be 10uf, electrolytic cap. But, on this he said no parallel caps. On other diagrams it show a 0.1uf, or two 0.15uf for the parallel tuning caps. So, take your pick. I found that the 0.1uf wima cap that I use gets too hot, depending on the frequency used. And mine cracked from the heat.   It is like I said before, you'll need the right voltage wima caps, to adjust and tune the frequency with. Low voltage caps will get hot and allow the full 5000v from the Kacher to interact with the rest of the circuit. That may be one reason why Geo's system can't self run, as well as mine. The 0.1uf wima caps are cheap, unlike the 0.47uf 2000v caps.
   I also said that it's one thing to use a SG with 20v on an empty grenade coil, it's another thing when it's all connected up using the push pull, bridge rectifier, ground line, etz... and once you connect the feed back path, much of the energy will get consumed by this loop, before it reaches the input side.
  conico, it would be good to see a picture of video of your current circuit, working, or not working.
AlienGrey
Nick, I hope you don't mind me saying so but you don't show the spark plug idea 'color' exposed here, so what's the point is copying your device if it's not complete and doesn't work. But note if you decide to adopt Ruslans hidden idea then it's obvious the bridge rect diodes need to be fast diodes and High Voltage before you start testing also i bet the HV device is not running all the time !
::) ;D ;D
NickZ
   Well that spark plug idea has not been replicated and shown to work. I am not working on that type of spark plug device.Perhaps, you'd like to build it up, instead of saying look here, look there, build this, build that, but you won't ever build it.
   Also, how would you know if a device works or doesn't, without building it? People have tried the simpler spark plug device, with out any advantage towards self running. How would you discover what has been hidden, without building a device?
   I do believe that the mode of operation of my type of system has to be something simple, but it may be the implementation of the simple process that we over complicate, and don't get quite right. My feelings are that it's all in the tuning of the frequencies, if the rest of the device is properly replicated.
AlienGrey
Quote from: NickZ on June 26, 2020, 10:49:30 AM
Yes if you look back on these tread I built such a circuit, it was good at destroying electronics it wasn't too particular !
What you are thinking is the European / yank oh i can weaponries that ! but what its doing is transferring energy into it's surroundings
that's why it needs to be layered in the rest of the device and focused.
