0 Members and 208 Guests are viewing this topic.
AlienGrey
Color hello,
Thanks for the info, so what method or circuit did you get results from to produce the nano pulse in your system ?
AG
conico
EMJunkie, thank you for your good intentions but I'm not working with microcontrollers. I have a multimeter with Arduino but when I start katcher it stops working. And first, I don't have time.
AG,
at 50% duty cycle of the 16Khz signal there are 10 (strokes) of 1.6Mhz signals and at lower duty cycle there will be fewer 1.6Mhz signals, 3.4, 6.
One of these 1.6Mhz signals will hit grenade coil and inductor in optimal time. It is easier to hit several times to hit once for good.
AlienGrey
yes i see  it all fales in to place now. thanks
color
AlienGrey :
Thanks for the info, so what method or circuit did you get results from to produce the nano pulse in your system?
What does nano pulse mean?
Are you saying how to create 1.54423Mh?
I do not have an oscilloscope.
soliman
Quote from: conico on July 02, 2020, 08:02:24 AM
AG,
Conico you are correct!.  you understood me.
there are two known ways to generate these pulses and to adjust
In this system, one is using nano pulse and the other is using tesla pulse.ud has to combine the PT to obtain one or the other, but never both. I only use nano pulse. This is good for me to generate a good ringing.
