color
https://www.youtube.com/watch?v=B4X5zy0piSg
In general, the simplest transistor/resistor/capacitor can be used to make a Tesla coil.
No logic circuit such as 74HC00 was applied to the Kapanase generator.
When the generator operates, resonance occurs in the secondary coil of the transformer, and the arc of the spark gap provides a certain amount of current to the secondary coil of the transformer.
The condition in which the arc may occur in the spark gap disappears, but resonance proceeds.
https://www.youtube.com/watch?v=ozGwb0glcXg
In other words, the secondary coil of the transformer takes away the Tesla coil arc.
Resonance still works.
Kapanase made resonance with two primary coils without a yoke transformer.
I don't know the Georgia power system, but I usually use AC110V/220V.
The converter is a device that converts AC voltage to DC voltage.
The voltage applied to the grenade coil by Kapanase is over DC220V.
About 2.35~2.65A comes out in 5KW lamp.
If you apply 220V instead of 12~24V to the Ruslan generator, it means that more than 5KW can be produced.
The yoke transformer is a device that helps resonance more effectively.
Without yoke ferrite, it is difficult to help resonance effectively.
It is assumed that Kapanase uses a converter to set the input voltage high.
5 KW nominal lamp consume !
How much these DC 220 V and 2,35-2,65 A reach this nominal value ?
100% duty cycle or works the coils arrangement also as duty cycle divider ( besides frequency and voltage divider potential) ?
justawatt
NickZ
   Color:   Again, please resize your images to less than 960 pixels wide. You are again messing up this page with your oversized pictures.
   Nobody has built a working Kapanadze replication, not even the Russians. Are you assuming to know what he has inside of the tin can??? I can tell you, but, it won't help. So, keep guessing... as there is no schematic, or full instructions to his devices.
   The reason that this thread was started was to work and discuss the Dally, Akula, Ruslan type of devices. Which do have diagrams, and all, even though there may be something not shown, hidden, or missing.
   The Kapanadze thread is where to place your ideas about TK's systems.
   Thanks again,
    NickZ
