0 Members and 161 Guests are viewing this topic.
NickZ
   Dear Grum:
   Almost sure, is like almost pregnant.  I'm almost sure it is not coming from nuclear decay, as is thought by some. Or there would sooner or later be some type of decay to be seen, and not in a 1000 years time, as an excuse for providing no proof to show for it.
  Akula may also state that he thinks its magnetic resonance, but that does not mean it is caused by nuclear decay. It can imply Earth magnetic resonance coming to and harvested from the surroundings, as he stated on the video.
ALL matter is created from, an by, the Aether.
The chicken did not produce itself, it came from a previous egg. And the egg was created by energy, within an energy field, without this energy from the vortex, no material object would exist.  Tesla was right, and is still right. So, is TK, Daly, Akula, Moray, etz...
  I do also remember your posts and contributions at Energetic, on the SR 193 thread.
  Too bad that it ended, I miss it still. Great thread, and some great posts.
magpwr
Quote from: Grumage on August 28, 2013, 11:49:22 AM
Dear magpwr.
Well let's just see if a schematic appears!!
The Ferite rings you spotted are CF 97 Mn Zn compound of around 7000 permeability. I got a qoute for Nanoperm  :o :o :o Over £300.00, far too much to pay for what could become another useless coil on the shelf!!
I love your enthusiasm, don't loose it, but might I suggest you pace yourself as regards the number of projects. Remember the old addage? Too many irons in the fire!! You might just miss that little something??
Cheers Grum.
hi Grumage,
I was puzzled as well which i recalled you previously mentioned about the nanoperm cores from magnetec.Because i find the price of core is truly insane.
I did execute order on Nanocrystalline toroid from www.cwsbytemark.com (45mm diameter).Cheaper alternative.
tips-
Before i commence my experiment i would normally plan all the possible combination in my head (like a Chess player).The 1st experiment i have execute more than 8 different technique each has it's own unique result.
This will save time during experiment which would be completed within a hour normally.
NickZ
   @ All:
   Here is another video that just came out by Igor Moroz. For those of you wondering if ferrite cores or air cores are the best type to use for this purpose.
Igor now has a 3 coil system, his induction coil is now an adjustable (moveable) Tesla type coil, using about 4 turns of 1/4 inch copper pipe, similar to what is used for the induction heater coils. His pick up coil is similar to Akulas, only going to the incandescent bulb. The high voltage output coil is made of thin magnet wire, going out of the output coil, and going to ground on one side of the coil, and out to the florescent tube light from the other side of the coil.
And a big moveable ferrite inner core. To help give this device its outstanding results.
  It's looking more and more like the latest Akula device.
  I'm assuming that the feed-back path is what will be done next.
   http://www.youtube.com/watch?v=LCqX5Y6jP3U
  I had invited Igor to join us, as I for one would love to see him here. But, my comments on his video inviting him to join our thread here, were not allowed on YouTube, and have been removed. Oh well...
        NickZ
magpwr
Quote from: NickZ on August 28, 2013, 08:58:15 PM
   @ All:
        NickZ
Hi Nickz,
The last few seconds he was honest and did mention about the power consumption is around 70...80watt to the induction coil.
I do like his videos nicely explained unlike me bad in verbal presentation in youtube. :D
Now if you studied various Kapanadze device eg:Akula and SR123.I noticed there is no real "consistent pattern" apart from hv generator which is a requirement for kapanadze device.
Now if you take a look which regards to "impedance match" you will notice the receiving coil for HV compared between Akula and SR193 device really differs alot.
For reference-This video using hv side of 2 ignition coil to transmit and receive power as shown below.
In this video shown below you can easily tell both the ignition coil  is matching pair likely operating in harmony/same frequency.Interesting amount of power is being received merely using 1 wire without using AV plug which consist of 2 diodes.
Radiant Oscillator Circuit / Don Smith Part 5: 0 Amps X 12 volts =12watts
http://www.youtube.com/watch?v=pDXKnk9hFMI
Hoppy
Quote from: magpwr on August 29, 2013, 02:31:55 AM
Hi Nickz,
Yes, he was honest and this is surely how Akula would have done it using a concealed wire back to the source supply, probably in his house. Igor demonstrates that an air core will work but clearly shows how the ferrite core improves coupling. IMO he dispels a lot of the mystery and bull.... shown on videos about this type of device running just from the tap of a 9V battery. In Igor's case, an earth wire is clearly essential, not to pull free energy from the ground but to provide a return path for the HV/HF power supply. He has now provided the incentive for others to experiment with power transmission over one very thin wire using the ground as a return, rather than wasting valuable time and effort trying to light KW's of lamps from the touch of a 9V PP3 battery.
