0 Members and 52 Guests are viewing this topic.
NickZ
  So, you guys got me wondering about the induction heating of an iron object inside the copper coil.  So, after dear Grum mentioned trying the different caps out, I found a 2 uf 250 volt one in my junk pile.  This I connected to my version of the Akula circuit, in series with  my 3 turn yoke coil, which is going to the 12 turn resonator coil that's wound over the big 43 turn air coil. Well, it did do something, as I was able to light a 65watt florescent bulb off of the big air coil, even without it even being grounded, or connect to anything. If fact grounding kills the effect on the florescent bulbs.  A neon bulb lights also, but not an incandescent, YET, This is without getting shocked at all, also.
NO cat in sight. Where are they when I need them...
And the aluminum sheeting (beer can aluminum sheet) placed inside of the air core, will light a florescent bulb, also. No shocks, either.
  Concerning the induction heating aspect, I have not been able to heat any iron inside my air coil yet. But, I'm only using 12v, and 1000mA at this time from a wall adapter. Tryng to go easy on my transistor, as don't have hardly any left, although I have more coming in a couple of days.
  So, the 2uf cap is doing something to complete the tank circuit for low volts, higher amps that won't shock you. Input was from my Joule Ringer oscillator's 1000v output.
  More to come...
magpwr
Hi Grumage and everyone,
After downloading the SR193 video and applying digital enhancement eg:anti shake,sharpening,fill light and remove noise for the entire video and after going through video only 6 times.
I believe i got the magic number(winding details) for SR193. :D
I have attached the SR193 layout.L2 coil winding is confirmed clockwise from the top if you refer to video or circuit diagram.
The number of connection located at the top of the device tallies with the circuit diagram 4 in total.No doubts about this.Not just the earth wire is going to center of toroid in tube.Refer to SR193 circuit diagram.
17 turns per layer ccw  turns at top half of coil (2 or 3 layer base on current wire thickness)  (This is the input coil(But mentioned as output transformer in video) from the 2 transistors)
17 turns per layer  cw below 1/2 of Kapanadze (3 layers)(Looks like real output coil.Step up transformer 220volts)
(Using the dot as guide on coil found on SR193 diagram i finally figured out what was the winding procedure like for all the coils) After i knew the winding details of L2 and compared with the dot by the coil on circuit diagram.
3:57min  -Subtitle- Spark gap just stimulates the process that takes place in ferromagnetic core
4:29min  -Subtitle-mentioned From output transformer power goes to 220v transformer below and closed loop is formed.
L2(1st layer on cylinder likely pvc) from the top connection is running in cw all the way to the bottom of cylinder.These is likely one layer likely 34 turns for the hv after spark gap.
The tricky part of the circuit is the driver stage for the input coil 50HZ.Using emulation i was able to get a near perfect sine wave.
(From internet search eg:220v inverter circuit with just 2 output to step up transformer.eg 12volt supply need to use 9volt transformer to 220v.)
My judgement the circuit diagram tallies with the video.No doubts about it.I will assemble this unit once i received the toroid to confirm the size with pvc pipe.
There is a possibility there is only 17 turns with just 1 or 2 layer for the input coil.Advise to construct last through trial and error to obtain maximum output from 220v coil.
T-1000
Quote from: magpwr on August 31, 2013, 08:22:28 AM
If you want to pursue SR193 circuit you need to understand how it worked. See the wire through inside tube made from ferrite rings? Without this it is just inverter. Now please see these successful experiments: http://www.youtube.com/watch?v=xuKiLjv0UqY , http://www.youtube.com/watch?v=qmirRN3O6Ko&list=PL1B521AB8CEB7C605&index=95 and http://www.youtube.com/watch?v=FNuoyPr4_NA&list=PL1B521AB8CEB7C605&index=96
This is what I think makes it self run due effect caused and utilized in full potential.
P.S If you get effect on your table please have Geiger counter ready as it might be NMR most likely.
MenofFather
In SR spark gap have what distance seems 2-3 mm? In 1 milimeter distance spark is 1000 volts, so in 2-3 mm about 2-3 kilovolts in sparks in SR spark gap?
NickZ
   T-1000:
   Why is this replication a success? It is barely lighting the bulb, ferrite rings and all.
How much input power/to output power?  Self running???
I don't understand, please explain.
