0 Members and 196 Guests are viewing this topic.
T-1000
Quote from: justawatt on December 05, 2020, 10:51:44 AM
2015 circuit from Ruslan.
Hello,
In greyed out text this circuit diagram is claiming to be from Alexey Sergeew (another guy with thousands of miles away from Riga).
What caught my attention there was the second Tesla coil pumping to the ground which was never shown in any of videos. The diagram claims it need to work on slight frequency  difference (20khz higher as example) with 10-20 meters distance of wet Earth between grounding of receiving grenade coil with it's Tesla coil. The difference of frequency between Tesla on grenade is the frequency grenade coil is tuned on LC/wavelength resonances.
Well, as nobody here tried this way only can guess what may happen. Perhaps that is a missing component all the time?
And from claims on Dniester device about secondary Tesla coil in other room this claim on secondary transmitting Tesla coil may be gaining some weight to actually try experiment on?
If anybody will try this approach, good luck with results and please share!
P.S> Akula device in Germany - https://www.youtube.com/watch?v=hIqEHc9_Bwo with receiving circuit which also may appear as secondary Tesla coil with thin wire.
Cheers!
justawatt
And 2 more things I noticed in photo.
He is tunning to the resonance frequency of the ground.
And only 1 wire is connected to bridge rectifier from the output grenade and other side of bridge he is connecting to ground
kolbacict
Grandfather Ivan(dedivan) says that energy can be added to the system if found  mode when ferrite will be cooled. This is our source of energy. Dissipated heat of the environment.
Quotehttps://www.skif.biz/index.php?name=Account&op=profile&userid=3978
T-1000
Quote from: justawatt on December 05, 2020, 01:15:01 PM
Yes, in that circuit diagram the receiving Tesla coil is tied over same output coil and capacitor to the ground. Which is for FM with high frequency carrier wave.
And akula also was tuning his coils to the ground connection frequency - https://www.youtube.com/watch?v=F6heKiZgSrU
In beginning of video showing self-resonant frequency of coil with floating end and ground connection over mains then with 2nd ground connection to water pipe.
Then knowing which frequency is to the ground adjusting whole circuitry to work in resonance with it.
P.S> the alexewsergey diagram above is using https://en.wikipedia.org/wiki/Superheterodyne_receiver method for 20khz frequency "transmitting" (which in reality is a difference between 2 Tesla coils).
magpwr
Quote from: T-1000 on December 05, 2020, 02:56:21 PM
Hi T-1000,
Additional findings for 2020 related to Akula circuit as attached.
