0 Members and 380 Guests are viewing this topic.
T-1000
Quote from: AlienGrey on December 13, 2020, 12:17:03 PM
There is a problem with that device Lithuanian experiment in that it uses a spark gap it produces radiation over the entire magnetic spectrum and beyond witch is OK if you don't mind the radiation !
When you have high voltage and need nanosecond pulse switching to discharge capacitors there are not much choices. Just the main thing is always missed out when you look on these videos.
The Caduceus coil was connected as one plate of capacitor and D. Smith style secondary as the second capacitor plate. The primary circuit see this as -capacitor- and nothing else. This is a main difference from all the rest of circuits you see in Internet.
In addition to that you get primary coil connected to Avramenko plug and doing these capacitor charge/discharge cycles to Caduceus coil. And the secondary in similar fashion over diode to charge capacitor with spark gap in series to load to discharge it. This is where magic happens when you have 100W incandescent bulb fully lit on output and almost no reaction to load in the primary circuit with far less energy consumption than expected.
This whole thing was way before akula/Dally and actually was understood by those people then improved. Which manifested as their devices. So here you go for the story part... ;)
AlienGrey
Quote from: T-1000 on December 13, 2020, 01:04:40 PM
T1000 I know what you are saying but lets re define and clear up the nano pulse thing it was explained in a good few of
the Russian language YOUTUBE video's it's not necessarily a nano width ultra fast up down pulse as such or down up
pulse it appears to be just a slow charge and a nano pulse DISCHARGE through the katcher secondary with a recovery time
it's used in high voltage Tesla Corona discharge displays circuits.
Notice the EXAMPLE circuit, it does not switch rail to rail and most of the power is lost in heat (wast) and is just a wast of space.  :o sorry  but it's true.
AG
justawatt
There is few more things in the circuit I shared
See the kacher part in left side Tesla coil he used 2sc5200 and diode towards the ground.
And in other right side Tesla coil he used 1943 and diode is from ground towards Tesla coil.
I have question for 700 khz and 720 khz what should be the length of the Tesla coil be. Will it be less than 10 cm
Jeg
Quote from: justawatt on December 14, 2020, 02:08:57 AM
Hi Justawatt
The length depends on your wire's diameter and your pipe's diameter. As a start go to this link.
https://www.everythingrf.com/rf-calculators/frequency-to-wavelength
You insert your frequency and you get the meters of the full wave. You divide it by 4 and you have your katcher's wire length.
For 700KHz you need 107m of wire for your katcher. Now, if you know the diameter of your pipe and wire, we can calculate the total length on pipe. ;)
