0 Members and 276 Guests are viewing this topic.
NickZ
  Itsu:   Thanks for doing the tests on the inductor.  I still don't know why you had such low output, too low to even weakly light a bulb. Perhaps this is a good time to review what went wrong. As both Geo and I could light several bulbs, fairly brightly, from either of the yoke's secondary outputs, or from the grenade's output. Geo even showed weakly lighting a 1000w bulb.
   From what I can remember, the output from the 3 turn coil was around 60v, and it was lower than the output from 28t coil.
Yet, the 3 turn coil's output, had a higher current output, as can be expected.   My unloaded output is over 1000v at the grenade's output.
   NickZ
   PS. itsu good to see you here, again.
AlienGrey
Quote from: T-1000 on December 15, 2020, 08:35:40 AM
The Akula's own explanation how device works is thread related.
And in his words it is like in magnetron. The electron emission on resonating receiver makes it work.
P.S> This is same method as in TPU devices or Testatika...
HI There a deeper information knowledge on the subject might be useful and
perhaps a build breakdown and circuitry would helpful.
AG
itsu
Quote from: NickZ on December 15, 2020, 10:13:36 AM
   NickZ
Hi Nick, thanks, i guess Jeg would like to know about that 60V.
I now have 390V AC sine wave unloaded on the Grenade and 88V AC square wave unloaded on the 16 turn secondary on the yoke.
I have 1KV across the wima cap and over 20A AC p-p (exceeding my current probe capabilities) sloshing around between the inductor and wima cap, all reactive, warming up the inductor coil.
So this 3 turn (22V AC square-like signal) and 16 turn secondaries on the yoke follow a roughly 1:5 relationship, with the 3 turn signal deformed by the series resonance signal.
At series resonance, the impedance is low, causing high amps and low voltage which is what we see at the 3 turn coil.
Input was 24V @ 3.5A, so about 84W.
Not sure why Jeg wants to know, but perhaps he will tell.
Itsu
AlienGrey
Quote from: itsu on December 15, 2020, 09:44:17 AM
Hi Jeg,
i still have my Grenade / inductor and drive (lossless clamp) yoke with the 3 turn coil etc., so i put it together and connected the 0.47uF Wima cap in series with the inductor, on the 3 turn coil.
Voltage on the Lossless clamp MOSFETs was 24V driven by the TL494 at 15V.
Series resonance was at 15.4KHz with 1KV!! sine wave across the Wima cap.
When measuring the 3 turn coil only i got the below signal.
So a square wave like signal deformed by the high sine wave resonance signal of the series LC, but relatively low peak to peak voltage (22.5V).
The Grenade coil was not connected to anything, also a 16 turn secondary on the yoke was not used.
Let me know if you want me to make some more measurements.
Regards itsu
Hi you lot still doing your own thing I see   ;D
where do you get the strange frequency your displaying on your scope
Try watching videos translated and Sergey's are very telling, still you wont listen
T-1000
Quote from: NickZ on December 15, 2020, 09:33:15 AM
   "Electron emissions" ???    What is that? You mean the HV and HF pulses (emissions) from the HV Tesla coil circuit?
    What would Tesla say to that explanation?  Concerning "electrons"...
A bit of memory refresh from different topic - http://purco.qc.ca/ftp/Overunity.com%20-%20Forum%20members/otto/ottos-open-tpu/ottotpu.pdf
Otto had this in his TPU - "The little transformer was pulsed. The primary. Secondary not connected. Every single pulse that hitted the little transformer, hitted also the multiturn coil around this little transformer but hitted also everything near the pulsed coil. So, this little transformer with his not worth to mention squared surface did a great job as a radiator of PARTICLES!!!! Yes, particles were fired into the surrounding of this little transformer."
And background knowledge for understanding what process akula had in mind - https://www.engineering.com/ElectronicsDesign/ElectronicsDesignArticles/ArticleID/16337/Vacuum-Tubes-The-World-Before-Transistors.aspx
Just no need of vacuum, all same in atmospheric pressure.
Hopefully this can clear gaps in common knowledge.
Cheers!
