0 Members and 410 Guests are viewing this topic.
NickZ
   Justawatt:   If you have not noticed, you are messing up the page by not resizing your images.   All your attached images need to be less than 960 pixels wide. I'm surprised that you don't know, or don't care.
   NickZ
AlienGrey
Hey, don't worry about that not every one can do that on a phone !!!! if you can't do that.
Nick does lots of videos and if any one tries to help him out he gets all moody  ;D ;D
he just likes to have a moan.  ;D ;D ;D
I didn't see him sorting out the guys filling the pages up with huge irreverent scripts !!
Look on the bright side you might end up sorting your living room table out  ;) ;)
NickZ
Quote from: Jeg on December 16, 2020, 06:43:40 AM
Thanks a lot for the effort Itsu!
I found it odd when realized that there is a voltage build up across the 3T coil which is the source coil for the in series resonant oscillation. I was expecting the coil to follow the turns/ratio rule. I experiment with tank circuits and their variables, and i wonder if there is any equation which predicts the voltage levels across the source coil when in series resonance takes place. We know that voltage and current are in phase across the 3T coil, but i can't find any equation which predicts the max voltage at that point.
   Jeg:  I have no voltage build up on the 3t coil circuit, it's steady.
   To predict the supposed maximum voltages, any yoke set up would need to be the exact same specs. Which they are not. Some yokes come from one place, and some yokes from other places. And they are made the same, nor are the windings that people are using on them the same, nor are they the same size, etz... And most Tv yokes are made to work at 15Khz, or so. At least that's what I understand.
   In any case, my yoke is still wound the Ruslan way. 12, 12 primaries, and the 3 turn coil, and 28t coil as secondaries. Runs best around 19KHz, or so, and so does my grenade, both circuits run at the same frequency. My simple Kacher runs best at 950KHz to 1.1MHz.
   What I think is, that my induction circuits, and the Kacher circuit are doing their thing perfectly, but, I don't see a proper sync between them. Which is the hardest part to get to see, especially for most any one that has taken the time to go this far. And  while incorporating the full feed back loop, back to the input. Which I think that only Geo and myself have ever shown connected up and working, so far.
AlienGrey
Just a watt you could delete your 2 pics now i re sized them
AlienGrey
Quote from: NickZ on December 16, 2020, 09:40:51 AM
   To predict the supposed maximum voltages, any yoke set up would need to be the exact same specs. Which they are not. Some yokes come from one place, and some yokes from other places. And they are not all made the same, nor are the windings that people are using on them the same, nor are they the same size, etz... Most Tv yokes are made to work at 15Khz, or so. At least that's what I understand.
   In any case, my yoke is still wound the Ruslan way. 12, 12 primaries, and the 3 turn coil, and 28t coil as secondaries. Runs best around 19KHz, or so, and so does my grenade, both induction circuits run at the same frequency. My simple Kacher runs best at 950KHz to 1.1MHz, as I've shown on my videos.
   What I think is, that my induction circuits, and the kacher circuit are doing their thing perfectly, but, I don't see a proper sync between them. Which is the hardest part to get to see, especially for most any one that has taken the time to go this far. And  while incorporating the full feed back loop, back to the input. Which I think that only Geo and myself have ever shown connected up and working, so far.
Nick that might be two high it could be just 3 times the push pull but then you have other problems as the 1mhz thing is for the disruption spike  perhaps it would be better to make a separate disrupter module like Geo described you might get some where then.
Or as your katcher is permanently running you would need to turn ithe HF part on and off in blocks at appropriate times it cant run all the time that simply does not work but then the the katcher needs to run all the time at 3 times the push pull and be in sync so it needs control.
it's in the texts and the Russian videos.
