0 Members and 356 Guests are viewing this topic.
Grumage
Quote from: 00 on September 12, 2013, 06:38:31 AM
we are just using the high frequency resonance  between thick copper coil with 320 turns central inductor inside alluminium tube. for resonance either slide in and out the alluminium tube  or slide the 320 (4x80 turns) turn coil module. all coils are wound anticlockwise. if you dont follow the winding dots for start of the wind  the circuit wont run and you will not have output.
00
Dear 00.
Like this??
Cheers Grum.
00
00
Quote from: Grumage on September 12, 2013, 02:55:12 PM
Dear 00.
Like this??
Cheers Grum.
hi grum!
yes like this but two layered each segment of 80 turns so 2(80+80)=320 turns
00
Grumage
Quote from: 00 on September 12, 2013, 04:19:14 PM
hi grum!
00
Dear 00.
That is what is wound on the coil above the Aluminium sleeve.
It still does not work though!!   :) :) :)
Cheers Grum.
00
Quote from: Grumage on September 12, 2013, 05:14:09 PM
Dear 00.
Cheers Grum.
hi grum!
is this your combination in figure below?
all coils are to be wound anticlockwise. including the inner 320 turn coil in two segments.
if outer coils wound anticlockwise and inner coil 320 turn wound clock wise then just swap wires of inner coil with outer yellow coil and cap connection.
00
