0 Members and 162 Guests are viewing this topic.
00
orthgonal winding variant two layered
00
Hoppy
Corrected inverter vs overunity winding diagram.
guruji
Hi 00
did you light a bulb with one layer on your setup?
Regarding 2 layered setup  so 1st from centre then 2nd layer 1inch gap to 1st layer then 2nd layer to centre.
Did I understood the windings?
Thanks
ctbenergy
Quote from: magpwr on September 19, 2013, 09:47:10 PM
hi everyone,
I have made an interesting discovery last night on my 3layers with 20 turns on each layer(CW) and 3layers with 20 turns on each layer(CCW)
2.5mm electrical wire was used for the windings.
After connecting both CW & CCW winding in the middle .Base on multimeter Ohm reading it's 0.9Ohm for each winding for both CW & CCW.
This is a interesting part.
Since we all know connecting 2 coils in "series" each with 0.9ohm should give us 0.9Ohm+0.9Ohm =1.8Ohm.
But for CW and CCW winding it's the reverse i'm getting 0.5Ohm since i know my multimeter can't give reading 0.45Ohm.It was simply rounded off to 0.5Ohm instead.
The resistance of the  2 windings in series consisting of CW & CCW became half instead of doubling.
It's like cancelling each other out.I wonder if "negative resistance" could be applied here.
"The only way to prove me wrong is to experiment.I know there is no error on my part"
hi magpwr,
I know there is no error on your part.
measured with Agilent U1733C
1 layer bifilar coil with 10 turns, 1.5mm CW (.0338Ohm)
1 layer bifilar coil with 10 turns, 1.5mm CCW (.0338Ohm)
2 coils in "series" (.0180Ohm)  :)
TheCell
The 12V Lamp is not lit.
However there is a small resonance that has maximum
when the thick coil is moved to the right.
With the osci - probe on the cap there are 1V pp .
The gap btw the 2ferrite coils is 1 inch = 2,5cm.
I don't have a thicker copper tube for the primary
, if this crucial for further improvements.
Please 00 give some advice.
