0 Members and 244 Guests are viewing this topic.
magpwr
hi everyone,
I have stumpled upon a very important document which is related to "1/4" or "1/2" wave" .This is based on a member name "Zilano" whom have succeeded in creating ou device in another forum.
But his post were all deleted-i don't know how that is possible.But this pdf was complied by someone whom was smart enough to gather all the information beforehand.
This are all based on Don smith ou device and which Kapanadze,SR193 based on.
Trust me without this attached document 100% of you will fail in creating a ou device.
Please read this attached document couple of times over at your own pace.
Everyone please download this document and copy to 2 different location locally while it last. :D
Hint-It  seems "you can't runaway from formulas"  :D :D :D
                    The only way to validate formula is to experiment related to the windings and etc to build up on experience.
Currently i'm just waiting out for parts to arrive and home renovation is about to start end of this month.
My project can only be resumed 3 or 4th week of Oct.
Pending parts to be delivered
1)Capacitors  (HV capacitors and 100,000uf 40VDC x 3 )
2)3x  50Amp (1000v) Bridge rectifier but i will be using only 1/2 bridge in parallel(50Amp x3) configuration       Experiment GEGENE  (http://jnaudin.free.fr/gegene/gegene13en.htm)
3)2 x 1000w 220volt (Grid tie inverter)        Experiment GEGENE  (http://jnaudin.free.fr/gegene/gegene13en.htm)
3)1000w (220v)  x 3 halogen bulb <$12 ea via ebay        Experiment GEGENE    (http://jnaudin.free.fr/gegene/gegene13en.htm)
4)Currently working with Barium ferrite Magnet producer on how to ship out item(It seems after placing magnets in small metal container.The magnet power still penetrate the metal case hence this item can't be delivered via air unless i pay USD$105 more for them to cover with wood /crate).I'm suggesting delivery via sea now just to cut cost and i'm not rushing delivery because of renovation. :D
5)NST 12volts 7.5KV 20mA 25khz...30KHZ  (This is for the experiment which was conducted in China and SR193)
6)small copper pipe to be locally sourced.  (This is for the experiment which was conducted in China)
7)10KV x 4 diodes to form bridge rectificer (This is for the experiment which was conducted in China)
8)Induction heater for GEGENE project -Need time to shop to purchase locally.
Barium Ferrite magnet will be used in 2 project
1) Resonance amplifier -http://www.rexresearch.com/mra/1mra.htm   (Previous test of mine merely with Barium titanate only gave me OU in mW at <0.5mA or below 500UA for <1uA input signal current at resonance).This OU device claim by inventor in the 90s will give out few watts of ou power.
2)VT SWEET -Not figured out this one yet,still gathering more information at this moment.
   What i do know at this moment conditioning of magnet using 450volts 1600uf would take 1 hour.There will be 3 winding on 3 axis of magnet.
    Amps pulse would be around 370Amp(omg) .Only time can tell if i'm able to conduct this experiment at all. :D
All this experiment to be done is merely for my own knowledge.I don't really recommend anyone to follow me unless you know what you are doing.
mrzlica
 Hi magpwr
I really hope you read the whole story on energetic forum, and how it ends.
It seems this is the same person (zilano) just another episode. I hope you will get luck,
or you can use the parts for another project. ;)
As you are 100% sure that  those so called plans are  winners, I`m 99% sure you will get no
pictures, video, or any proof from 00. :(
Good luck.
One more thing, when you will build one of the devices and it doesn't work, you will get no reply  just another scheme.
00
the effect!
ac is superimposed upon dc.
for overunity make dc  voltage pulse at higher frequency say 30  to 80 khz (single layer orthogonal coil) and superimpose( ac 50 hz that means modulate) then resonate modulated dc to interact with 50 hz ac with dual layer orthogonal coil terminating in output reverse phase to orthogonal coil as akula did you will get overunity surely.
00
NickZ
   00:  It flashed? That's it?   Amazing!
magpwr
Quote from: mrzlica on September 24, 2013, 02:26:52 AM
Hi magpwr
Good luck.
hi mrzlica,
The estimated current cost for these 4 ou experiment is merely around 1/3 the cost of my HHO project.If you search youtube "1 watt HHO" that's my experiment posted.It can be done.
There is still room for improvement by using "Super corona dope" coating on tube but it's only sold in the USA and can't be exported out and a suitable small cut need to be made on outer tube to match resonance with smaller tube.
Inner and outer 316L tube spacing to be made smaller.
If 3 out of 4 ou experiment fails these merely become small problem for me.Like all electronic components it will be reused for some other experiment. ;D
By the way how is it "zilano" posting was deleted since he was successful.Maybe you didn't read the contents of the attachment.
Did you see anyone else in internet explain on 1/4 wave and 1/2 wave in full details down to the formula and the pitfalls to avoid.
These ou devices requires the accuracy of a watch to get the standing wave or resonance.
It's merely around 1 month+ for me in these Kapanadze thread and yet i already got sufficient knowledge about these devices.
So the GEGENE experiment in Jln lab is a fake for you with all the reports they posted.That experiment is still work a in progress.
It's easy to spell "fake" by anyone whom do not not know how ou device work.
