0 Members and 166 Guests are viewing this topic.
totoalas
Quote from: NickZ on September 25, 2013, 08:33:12 PM
  This can easily be tested, and is caused by stray AC capacitance, and induction that's running in your AC house wiring.  Running even on the floor, tables, and even up through ones body.  And most likely NOT from the above explanation, or diagram.
  To test this: Turn your electricity meter switch OFF,  and you will see how the device, and the led lights all go out. This is usually caused by a less than proper ground connection at your outside meters AC grounding rod. So, this is Not free energy, and usually won't have much amps to it, mostly fluffy voltage, that will light only LEDs.
  That's why a 12v battery and  inverter are important to use for these tests, instead of the house ground or neutral.
  Just turn your meter off, and see for yourself.
  If this is not the case, let us know.
Youre correct   when dc transformer was isolated the lights switched off    .....  and thats why your recommended battery and inverter is on my next test......
magpwr
Quote from: guruji on September 25, 2013, 07:58:06 AM
That's Don smith circuit you can find it everywhere even on this forum.
Same to Bottle cap I found it on youtube how to make one. It's very simple just fill a bottle with salt water and insert a piece of coil wire to it from the cap.
Wrap aluminium foil around and you have it.
That's pvc pipe wrapped by another coil.
That experiment was'nt OU but again one has to go in resonance as 00;Don Smith and others  said.
Regards.
I don't want to put people down by my experiments for sure.
Wish well to all engineers;electricians and all but yes perseverance is a great key in everthing that we do in life.
Searching like anyone else to get an OU circuit.
Regards.
hi guruji,
I have just seen your latest video uploaded around 6 months ago on "Kapagen" where you light the 40watt bulb powered by spark.
May i ask did you apply the 1/4 or 1/2 wave formula for the windings revealed by Zilano or someone.
http://www.youtube.com/watch?v=ESjVbFTV-5s
Nightmare_T34
Enjoy  ;)
This really makes some sense ...
Any suggestions about the device ? Theoretically , for now.
Kind a funny fact. If you google "E-STRESS POWER GENERATING SYSTEM" there is only TWO related web pages...
guruji
Quote from: magpwr on September 25, 2013, 09:41:45 PM
hi guruji,
Hi magpwr
No I just winded as the shown schematic. No formulas.
Zilano was great she had alot of knowledge on these devices. It was a pity that she stopped posting.
Hi Nightmare with that file you reminded me on that russian vid of that guy in snow running a coil with an aluminium foil in it.
Interesting thanks.
Hi 00 I messaged you but if you don't like PM it's ok.
Regarding the coils should they be in same inductance?
And for the cap one have to add the sum of the two coils for LC.
Thanks
magpwr
Quote from: guruji on September 26, 2013, 06:54:28 AM
Hi magpwr
Interesting thanks.
Thanks
hi guruji,
From your kapagen video i noticed you used copper tube without a slit on the length of the tube.
There is a document i think it was posted by stivep1 in the another kapanadze thread in this site around 2 weeks ago.
In it mentioned copper tube loop should not be closed and there would be a gap.What i noticed it's around 1.3cm...1.5cm wide from other videos.
Honestly i don't know these would help to boost efficiency since i'm merely gathering parts at this moment.
