0 Members and 267 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on October 11, 2013, 04:37:10 PM
Hoppy. I have been told that Kapanadze can take a day to tune his device. I have been told that Akula has taken 3 DAYS to tune his device. It could be as simple as persevering.
Good luck.
Interesting. This strongly suggests that the Kapanadze devices are extremely load sensitive in terms of impedance. I have noticed with the setup I described, it is possible to reduce the supply voltage considerably without a noticeable loss of bulb brightness but it is fiddly to find the right point to start the reduction. At this point the bulb will be at max brightness but may suddenly pulse intermittently or flicker somewhat like the Kapanadze lamp arrays. A 10W or 40W lamp will not run as efficiently as a 60W bulb on my setup.
NickZ
  The latest Igor Moroz video is showing how the Royer inductor oscillator can light 2000 watts of Halogen bulbs, or so, using less than 1/10 the power. No thick output cables needed, and no shocks, either. Although I honestly can't understand all of what is being said, as it's in Russian.  Once the feed back circuit is achieved, which we hope to be real soon, we should see a  self-runner, that may show us the next direction to take.
Here's hoping, anyway...
  Hoppy: Even though you've seen good useable output from your Royer/ JR 3.0 circuit, using air coils, just think how much stronger it would be, if a high perm ferrite core were  placed inside, as Igor is showing.
  Lynxsteam is selling his version of the JR 3.0 single 2n3055 transistor circuit, but using only air cores, instead. At $68, or so, each. Which are able to light several (6 to 12) 7.5 watt Utilitec bulbs.
  These JR 3.0 type circuits are a very simple, cheap, and efficient inverters... But, we need to see IF it can also be feed-back to the input side, to run itself, or not?
That is the question that I have, as it's easier said than done.
  So, the circuit that you now have running, Hoppy, may be a good one to try the feed-back on.  Maybe check Igors latest video for the way to do this.
Nightmare_T34
This is the part of Tariel's ( Kapanadze ) schematic ! Now the rest is for us to figure out ! We need to create electrostatic HV field on the SAME frequency as Tesla's Transformer resonant frequency ! This is the way to get free energy !
a.king21
Nightmare:- A bifilar coil pack is a capacitive coil. Static should exist between the separate coil windings.
I suspect the coils have to be wound in the opposite direction.
This static is Lenz free. And it is bound to be in resonance.
Kapanadze told me that his device ABSOLUTELY needs Bifilar coils.
ABSOLUTELY!!
(I got it out of him in a round about way after hours of discussion regarding the miniaturization of his device.)
T-1000
Quote from: a.king21 on October 11, 2013, 11:02:57 PM
ABSOLUTELY!!
The static field of Tesla coil is free particles donor. The magnetic field of second series resonant circuit on 90 degrees is what makes those particles stick to the wire so here the amplification of power goes.
Please read http://peswiki.com/index.php/Directory:Resonant_Nuclear_Reactor and substitute radioactive source to Tesla coil. The rest of circuit is still there.
P.S> Still trying to get through all information what http://globalbem.com/ is making over live conference, it was second day of three full of scientific presentations. 4 am here now but can't sleep... :)
