0 Members and 319 Guests are viewing this topic.
Khwartz
Quote from: woopy on October 15, 2013, 06:42:15 PM
Hi all
here my replication
I was awaiting a good occasion to finally build  the flyback Mazilly ROYER oscillator , and this experiment push me to finally complete it
it seems to work correctly, on   12 volts and more , i can light incandescent bulbs  (not fully lit  ) with a ratio of each  flip- flop as per Geofusion indication
The tuning capacitor seems to be  very important  and i have to test much more  different settings.
Far from being OU at my level, i have to test much more
My yoke is a standard old TV
So guys at work
Laurent
Salut Laurent !
I happy to see you working on this subject :) Indeed, I nor the time, the place, and the skills or the money to experiment such device so I am happy when someone like you having integrity and showing completely what is working actually or not, been honest and frank, care about to test them.
Thanks for doing what you do!
Sincèrement,
Didier
Khwartz
Quote from: Hoppy on October 16, 2013, 03:53:19 AM
Please also use a scope if you have one, to measure supply current using a shunt resistor and if at all possible post a shot of the full scope screen so that other experimenters can see data like the Pk-Pk and RMS voltages across the shunt resistor of a specified value. Its of paramount importance that experimenters use methods of measurement that are fit for purpose. Without this data, device efficiency and performance comparisons are not possible to determine.
Very nice you advise such rigour in the measurements, dear Hoppy.
In the same veine, I remember that to use light bulbs without comparition bulbs for the lighting means near nothing or is very unaccurate.
Indeed, one can give 500 W, because only 120 V of voltage harvested, to ten 100 W-240 V bulbs and light them.
Need to have always aside of the light bulbs load at least one same light bulb under its full normal voltage, so the brightness of each could be compared.
Could look insignificant, but quite important when it is about to check a possible overunity of only few points...
Amicalement.
MenofFather
MenofFather
Hi all
here my replication
So guys at work
Laurent
To not destroy resonance must be small air gap betwen primary and secondary-output windings. When system must work on almost any capasitors bank, but better on about 2-0.1 uF.
MenofFather
Here is mine, I ry make selfrunning, but not get to it run self.
Input be 20 volts. Output 24volts with one diode and capasitors. (24 volts on capasitor output.) Resonant capasitor is 1 uF i chose. Secondary coil have gap betwen primary. Primary coil have about 10 and 10 turns to same direction windings of corse. Inductor is from thre inductors in series. Transistors (mosfets) 55 Volts 49 amperes.
Беспорядок и слабое качество что ничего не понять, как и подобает СЕ искателю. :D
