0 Members and 54 Guests are viewing this topic.
NickZ
   Until proof can be shown that not only a capacitor or battery can be charged from the feed back of the device output, what we are seeing is just an efficient inverter. And not only charged back (as in feed-back), as my Joule Ringer circuits is charging back the battery, and I can even light a neon bulb on an AV plug off of the 12v battery positive terminal when the device is running.  But, that does not mean that the device will not still drain the battery. If you follow my drift, especially while bulbs are drawing 1000 to 3000 watts.
  Self running, with or without a battery is the real key to this.  As any hefty car inverter will light 110 or 220v bulbs, while discharging the battery.
  I'm not being a naysayer, I'm being real... So, don't get too exited just being able to light bulbs, until this self charging self running aspect is perfected, and replicated.
T-1000
Quote from: NickZ on October 16, 2013, 02:24:18 PM
To make it self running the battery becomes part of resonant circuit. Bedini way of resonant battery charging is the key!
http://www.energyscienceforum.com/showthread.php?t=125&page=34&p=10524&viewfull=1#post10524
The rest you can design in way you want just the main thing is to keep hitting battery with BEMF high voltage pulses on its internal ions resonant frequency.
This is not very related to Dally stuff but anyway, it is one of many ways to Roma.. :)
Cheers!
Grumage
Dear GeoFusion.
I have attached a pencil sketch of the two methods of winding the primary. Please would you indicate which one you have used? I have sat at the kitchen table and rotated my fingers and you will see if you try it yourself the fact that starting out from the centre going each way (behind yoke and coming forward)  they both still have a CW/CCW relationship!! Looking from each end!!
As requested please find attached photo of my setup.
Cheers Grum.
Khwartz
Quote from: Hoppy on October 16, 2013, 12:48:21 PM
Very good tip Khwartz about having a light bulb running on normal grid voltage next to the bulb being powered by the device under test. Its much easier to make a comparison of light levels this way. Another worthwhile exercise is to run a bulb from a grid fed variac on a power meter and note light levels v power levels. This is an eye opener which will show how easy it is to overestimate the power being dissipated by the bulb. Of course the most accurate measurement is achieved using a light meter measuring bulbs in a suitable enclosure.
Good measurements will show that setups of the build posted on this thread will typically run at roughly between 50% and 70% efficiency. The critical factors are getting the turns ratio, wire gauge and the air gap between primary and secondary optimised to load when using tubular coil formers. The 64K$ question is whether its possible to loop back this type of system running at under unity electrical efficiency, so as to self-run. I have seen no hard evidence that this has been achieved by anyone to date but I live in hope that the NMR experimentation being conducted by Wesley and his team and a few others will bring success.
I see you have very few to learn from me but I'm not surprised, I have seen you in your experiments with several replications in Conspirovniscience ;)
Very good idea this grid fed variac :)
Here few links you could be interested in it, around NMR experimentations:
Of Selfonlypath (French too but vid in english) ; you will find in his former vids about air gap and all kind of resonating effects:
"Extreme NonLinear Power Electronics / Part 1" : https://www.youtube.com/watch?v=wY4dRvYvwOs&feature=youtube_gdata_player
"Andrey Melnichenko - Ferromagnetic Free Energy Generation - up to 150% Efficient."
https://www.youtube.com/watch?v=F8c82ABs02M&feature=youtube_gdata_player
Very different ways and level of technicity and second could be is not o.u. either ;)
Otherwise would you say that the Gegene and Richard Vialle theories subproducts have not produced stable and usefull o.u. yet?
Amicalement,
Didier
NickZ
 quote:
  "This is not very related to Dally stuff but anyway",
                                                               end quote.
  T-1000: Yes, you're right. It not related to what Dally, Akula, Tk, or others we are dealing with here have done.
But, what Igor Moroz is currently doing towards this end, (on YouTube), is.
  There seams to be a couple ways to go about incorporating this feed back process.
The use of an inverter, is one way, although SR 193 did not need one, but, he couldn't obtain an output any higher that 150 watts. But he needed only a 9 volt battery to jump-start the device, as does Andreij now showing 300 watt output, or so,  and only needing an earth ground, once the device is started. So, there are several ways to go.
    Akula has shown us his feed-back path, by the use of a big AC filter cap/rectifier set up, to step down the higher output voltage, to 12v.  Or, how TK did it, by using a step down transformer instead.
So, a filter capacitor/rectifier/inverter set up like Akula has used.  Or, a step down transformer, battery/inverter, set up, like Tk used.
  I would think that if an expensive pure sign wave inverter and car battery can be avoided, the better. Even if a lower voltage and current are obtained at first for now, as it will allow more people to be able to replicate, without much higher expenses. As Igor has mentioned that the capacitors that he uses are $50 a shot.  Not cheap...
