0 Members and 1017 Guests are viewing this topic.
GeoFusion
Quote from: Grumage on October 16, 2013, 03:21:38 PM
Dear GeoFusion.
I have attached a pencil sketch of the two methods of winding the primary. Please would you indicate which one you have used? I have sat at the kitchen table and rotated my fingers and you will see if you try it yourself the fact that starting out from the centre going each way (behind yoke and coming forward)  they both still have a CW/CCW relationship!! Looking from each end!!
As requested please find attached photo of my setup.
Cheers Grum.
Hi Grum :),
Makes me happy to see you guyz all trying it out and working on it together.
I will be posting a newer vid later today.
Something new. to the eye.
I have indicated the one you should be using.  The Same Direction one.
the first coiling. the other method was not tested yet.
cheerz~
Kator01
Folks,
I simply dont get it !
The same silly stuff is posted now again concerning cw-ccw as it has happened some time ago
with this Chubinidze-coil-desinformation.
Whenever you wind a coil in one direction eg. cw , it does not matter from which side you
look at it, it is always cw and does not magically change direction.
This is really annoying.
The scheme of the coil at the bottom of coiling2.png is correct and is the Koenig-Coil,
European Patent EP0287307A1, dated 1988. Advantages of this coil-setup and how to connect it to the driver is described in the patent.
Hope this settles this issue once and for all.
Kator01
NickZ
  I don't see what the confusion is about ,with GeoFusion's same direction, center tap primary coil advice.  I got it.  It's very simple. Just wind the primary coil one way, tap it in the center.
  But, what has not been tested is if it actually makes a real difference to go in opposite directions, and just what the difference is. More or less power output, or is it just the same thing, and makes no difference at all.  It made no difference in my case, at least that I could see on my Akula yoke replication.  But, I'll try it again, only take a few minutes to reverse one side of the coil, and take reading one way, or the other.
Then we'll know.
  There are many variations of the Royer induction heater circuit. But, which is the best one for our purposes?  The one that works, maybe, huh?  Cuz, up to just now,  none have worked to self run the circuit.  Unless you got magic shoes on,  like Geo.
MenofFather
I try, work normal with one choke, better than with two and same work (with load and without load same current) then taped to center. :D
