0 Members and 594 Guests are viewing this topic.
Khwartz
Quote from: GeoFusion on November 30, 2013, 11:34:03 AM
Hi guyz :)
totoalas :
yes, I will be posting a vid about the motor/gen soon but as I have linked you guyz  to a video in one of my comment above it does the same work. :)
Uh my motor is 3400 RMP speed. 1/3 HP
Generator 4KW. 120V and 220V 60Hz.
Just make sure to get a motor that has a RMP of 3400~ to 3600. Gasoline engines are around those rates.  Speed counts alot hear for more energy production.
not HP though, sins it will not need alot of torque, only a bit when it starts to spin.
Cheerz (=
Hi Geo! :D So Very Nice To See You Back! :) Were missing you! :)
As one of my trades and training is electrician (not at all in electronics! lol) I am especially interested in these kind of motor-generators.
I have studied one shown with very little motors but could find (yet) the exact characteristics which made them work. Could you help me on that point? like taking pics of each data cards of each (motor and gen), so we could have all the characteristics, mark, series number, type of, etc. This mainly important to me.
Any way, you probably tried other configurations; could you tell which ones were working and which were not? with pics of data cards of each motor or gen? a table with a "+" in the cells of the couples which works, "-" for couples doesn't work and "0" for not tried, would be a must ;)
So Very Thanks For Sharing Freely And Help Provided,
cheers,
Khwartz.
magpwr
Quote from: GeoFusion on December 01, 2013, 04:24:23 PM
Hi there guyz  ;D
a.king:
Yes, i will try that method :) , ty. I will make a 4th video about it also or just to let know here on thread about the measurements with pictures. thnk you for letting me know. other wise I should get some analog meters might work xP
magpwr:
Hi :) , I have seen your Uploaded vid of your replicated Roundcore.
I really am starting to like your version of Royer circuit sins it has those 600Volt mosfets that are hardcore and can handle presure. I should start looking for them xP.
By the way, I think your Royer Circuit can handle 120Vdc input (= or a bit less voltages around 60Vdc or so.
I have a schematic of it where 500V 44A mosfets are used instead of the IRFP250's or IRFP260's where it can work with 120Vdc! just imagine what the output would be If I managed things with 12 to 24 volts only XD!!! haha masssive output.
Hmmm Might be that your core is not properly set for it to produce energy with acoustics.
The windings seem ok, 27 and 8-0-8.
Both halfs of the yoke is insulated, Both half pieces.
!!Important!!:
one layer of paper or tape inbetween the 2 splits of the ferrite yoke. That is needed for it to function :)
Guyz, I have upload the Part 3 Video of Igor's TROS system MOD.
Might come in usefull information and capabilities of Radiant electricity usage :) .
Part 3 :Igor's TROS system Mod part 3 With water, CFL's and Motor
https://www.youtube.com/watch?v=FD8FcUKo-tY
Enjoy
Cheerz!  ;D
hi Geofusion,
Finally i have some success in lighting 1KW 220volt halogen Tube for the first time after following your suggestion to insulate the one half of yoke core with paper tape.
There is still room for improvement to boost output power which i'm currently working on.The current draw on 12volt battery is little high at the moment.No Mosfet smoked yet. :D
I have just uploaded video GeoFusion roundcore replication attempt v2.0 on youtube
http://www.youtube.com/watch?v=aamlORcj-fY
Do advise us how do you find the sweet spot winding the yoke to allow it to ring or is there anything else amiss which i would need to look out for maybe using my scope to look out for something eg:resonance.
I just had a creative thought- Since you had no problem powering 1KW Halogen tube i wonder if you are able to power cheap Infrared bread toaster/Infrared toaster normally rated around 400 to 800watt.
I have successfully cooked minced seasoned chicken/fish  in it besides toasting bread.This infrared toaster doesn't use electronic at all it's merely uses winding base timer and Infrared heat tube.Imagine running these on 12volt battery. :D
Thanks again for your suggestion. :D
Ed morbus
itsu
Quote from: magpwr on December 02, 2013, 03:17:44 AM
hi Geofusion,
Finally i have some success in lighting 1KW 220volt halogen Tube.................................
Magpwr, GeoFusion,
great to see you have some success magpwr, only the comment from GeoFusion on your question about the used nbr of windings (The windings seem ok, 27 and 8-0-8) puzzles me as my present yoke primary and secondary windings are:
QuotePrimary is 2x 21 turns of 2.5mm2 solid copper wire, 2x 59uH
secondary is 60 turns of 1.5mm2 solid copper wire, 478uH
See here:  http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg376436/#msg376436
Also GeoFusion mentioned similar nbr of windings here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg373340/#msg373340
QuoteYes the Primary Coil with center tap is wound the same direction,from left to right , CW to CCW one coil.
and Secondary Coil is also wound the same direction as the primary.
Primary has 27 winds of 2.5mm² Insulated wire  and secondary has around 35 winds of 1.5mm² insulated wire.
I would also remove the metal brackets as Ed morbus mentioned and use electrical tape to fix the both halfs.
Anyway,  my batch of 47n60c3's did not arrive yet, but i will test with those again.
I did some further tests with the 3x halogene (550W) bulbs under tap water, but now with 2x 2.2uF caps between bulbs and secondary coil.
The 2.2uF caps means about 45 Ohm reactance at the 1.7KHz.
It did not made any difference compared without the caps, i still feel the tinteling when spreading 2 fingers apart in the water, and a FWBR made of 4x UF4007 diodes connected to a 330uF/400V cap made the cap voltage rise to 75V.
However, when connecting a small motor (CD tray type of thing) or a 6V bulb to the cap showed nothing (not able to build up any voltage then).
Regards Itsu
GeoFusion
Hi  Guyz   ;D
Khwartz:
Hi  ;D Yes I'm back and all ok haha.
Ahh electrician :), that is awesome, we need some people like that on the field of Motor/Generator. I am but a mix of Electrician and for small adv. electronics repair and experimental (=.
Sure, :) I will be posting on the Thread too, Pictures and Videos of this 100% working device. Yet a very simple one, I had no idea It could be Done like that, But a great relief and my house works on it  :).
I could start mentioning some specs of another one I made ( motor/generator )
it's a 120Vac Motor, 3400 RMP ,1/3 Hp
Generator - Brushless 2.5 KW 120Vac , 220Vac,
But this one I connected a belt with pullies. :)
Switch in between the output of the Gen and motor for the Gen to feedback the Motor, Make sure your gen produces the Hz that the motor needs! very important, like mines are 60hz, and needs to produce 60hz as it spins :).
as  fabricated as it was earlier on a gasoline engine hehe.
Previous  Generator of 4KW is with direct shafting, but I think I'm limiting my self there sins you could put more connects of you use belts and pullies like a Flywheel  , but it's great of use!! xD
magpwr:
Greatt Newss!!! :D Finally, see that insulation of the splits is what you missed which i mentioned in earlier posts in these threads.
1KW 220, waw :), mines was a 1KW 120V.
But as you can see the amps are like a beast, alot of amps, but guesing the winds do play a great role in this.
I was thinking to Mod the circuit, and place a Frequency Gen. at the Gates of the mosfets, It should make the Lights brigher when raising the frequency there :).
I would suggest to try out as the same winds I have :) for the try out, Oh and make sure the two insulated splits are hard pressed on eachother for better results.
I do see you have everything right there, but I am starting to love you Circuit sins it doesn't heat up, this is a very good update and upgrading for these systems :)!!
I would test those toasters, no problem (= , I should buy one of those infra toasters though.
But nice xP
Oh yeah don't forget I removed the clips but If you have them Insulated like i see, it's all cool , but my original one has no clips,
I just used black electrical tape to Hold the two halfs together :) and hard!
Itsu :
Hi :), yes guessing you should try out my windings as how I have but you also managed alot while replicating it   ;D it's all good.
But always better to replicated it as exactly as shown , that it what i have done many times When i replicate someone's invention.
And yes, with water you will feel a bit of the electricity tinteling on the fingers, sins it kinda acts like a storage of energy too.
Like a capacitor . :) there is a vid I will be posting today and it will show that water has something extra ordinary with Radiant energy.
let me know if anything guyz
Cheerz!
