0 Members and 83 Guests are viewing this topic.
magpwr
Quote from: GeoFusion on December 02, 2013, 09:11:08 AM
Hi  Guyz   ;D
Khwartz:
Hi  ;D Yes I'm back and all ok haha.
Ahh electrician :) , that is awesome, we need some people like that on the field of Motor/Generator. I am but a mix of Electrician and for small adv. electronics repair and experimental (=.
Sure, :) I will be posting on the Thread too, Pictures and Videos of this 100% working device. Yet a very simple one, I had no idea It could be Done like that, But a great relief and my house works on it  :) .
I could start mentioning some specs of another one I made ( motor/generator )
it's a 120Vac Motor, 3400 RMP ,1/3 Hp
Generator - Brushless 2.5 KW 120Vac , 220Vac,
But this one I connected a belt with pullies. :)
Switch in between the output of the Gen and motor for the Gen to feedback the Motor, Make sure your gen produces the Hz that the motor needs! very important, like mines are 60hz, and needs to produce 60hz as it spins :) .
as  fabricated as it was earlier on a gasoline engine hehe.
Previous  Generator of 4KW is with direct shafting, but I think I'm limiting my self there sins you could put more connects of you use belts and pullies like a Flywheel  , but it's great of use!! xD
magpwr:
Greatt Newss!!! :D Finally, see that insulation of the splits is what you missed which i mentioned in earlier posts in these threads.
1KW 220, waw :) , mines was a 1KW 120V.
But as you can see the amps are like a beast, alot of amps, but guesing the winds do play a great role in this.
I was thinking to Mod the circuit, and place a Frequency Gen. at the Gates of the mosfets, It should make the Lights brigher when raising the frequency there :) .
I would suggest to try out as the same winds I have :) for the try out, Oh and make sure the two insulated splits are hard pressed on eachother for better results.
I do see you have everything right there, but I am starting to love you Circuit sins it doesn't heat up, this is a very good update and upgrading for these systems :) !!
I would test those toasters, no problem (= , I should buy one of those infra toasters though.
But nice xP
Oh yeah don't forget I removed the clips but If you have them Insulated like i see, it's all cool , but my original one has no clips,
I just used black electrical tape to Hold the two halfs together :) and hard!
Itsu :
Hi :) , yes guessing you should try out my windings as how I have but you also managed alot while replicating it   ;D it's all good.
But always better to replicated it as exactly as shown , that it what i have done many times When i replicate someone's invention.
And yes, with water you will feel a bit of the electricity tinteling on the fingers, sins it kinda acts like a storage of energy too.
Like a capacitor . :) there is a vid I will be posting today and it will show that water has something extra ordinary with Radiant energy.
let me know if anything guyz
Cheerz!
hi Geofusion,
Thanks for the reply.I just realized my 1KW 220volt bulb was different from yours 120volts version.haha.I have completely overlooked this part.Now it make some sense why the 220volt tube was dim for me.
I will try my luck some other time to increase winding from 27 to 50 or more (on my mini yoke meant for 14inch TV) to provide power for my 220volt 1KW bulb. ;)
I will release version 3.0 video if i am successful. :o
The heating\warming up on mosfet did not happen at all on my 1st video using HV transformer with similar circuit.But for Yoke coil setup there is heat on mosfet but within manageable range.
I am starting to think if i were to use similar value capacitor 0.38uf but with "low ESR Rating" like those found in induction heater.It may help to boost output.But this is just theory for now.
T-1000
@GeoFusion and others
To stop blowing your MOSFETs the missing part are Zener diodes on gates to protect from overvoltage and the original circuit came from http://adammunich.com/zvs-driver/
Also this circuit was used in my team's first Lithuanian experiment for driving flyback transformer.
Cheers!
Grumage
Dear GeoFusion.
Try as I might I cannot see the whole of your schematic from your recent video. Would you be so kind as to redraw and post here ??  :)
I did see that there are a few changes..... Single 2N3055 driver ( They are the toughest transistors I know........ John Wayne transistors ??  :D )
I noted also you have a mix of Iron and Copper conductors too!!
A re drawn schematic would be a great help to us all.
Cheers Grum.
Hoppy
Quote from: Grumage on December 02, 2013, 12:45:33 PM
Dear GeoFusion.
Cheers Grum.
Evening Grum,
Then you have'nt tried the MJL21194 then?
Question for Gerofusion: You specify solid 1.5, 2.5 & 4.0mm sq wire on your RMG schematic. Does this wire really have a single solid conductor and confirm that its gauge is a squared measurement rather than a measurement of core diameter? Also, can you please advise where this wire can be obtained from?
Grumage
Quote from: Hoppy on December 02, 2013, 01:06:32 PM
Evening Grum,
Evening Hoppy.
What?? tougher than John Wayne ?? But seriously no I have not. They do have a good Voltage. Is this something you would recommend??
Cheers Grum.
