0 Members and 125 Guests are viewing this topic.
NickZ
  Geo:
   Thanks for your comments, I'd be glad to try the thin shorting wire, maybe if you can explain where to connect it, so that I don't make a mistake.
  Here is a pic of what the crt looks like to this point.
GeoFusion
Quote from: NickZ on January 13, 2014, 12:47:54 PM
  Geo:
Hi there Nick,
Great Uploaded pic of the start of replication ;D
When you have the zeners for the protection of circuit, make sure the zeners are 15volts up or 18Volts like I have (had) then try 24 Volts aight.
Btw The Flyback pice primary coil is good , but try to mirror the coiling way of the primary to the secondary one,
Look at my vids or Schematic you will see (=, Take a good look at the coiling on the flyback piece on the primary and secondary
But Glad to see this being replicated (=, Why is it so important to experiment, is because you will eventually learn more automatically and understand further things to with these devices. That is how I managed to understand all these things too. alot of experimentations.
when your busy again, try larger cap bank (=. see the results of amps at the input and output
NickZ
  Geo:
   Ok, thanks again for the reply.
   Here is a clearer picture of the circuit and flyback core.  There are 10 turns on each side, of the flyback, and center tapped on the primary coil. Is there something that needs to be changed there?
  I find that if I separate the splits about 1/8 inch or so apart, there is higher output at the bulb.
  Remember to let me know how to connect the "thin wire", that you mentioned previously.
  What value were those tuning caps that you are using?
GeoFusion
Nick:
Yes, there will be some Changes for sure :).
circuit seems to be ok for now, but remember to get the zeners. Zeners will go where the 10Kohm resistors are.
Yes that is true, sometimes it depends the distance of the splits that makes the output load be more :).but try to maintain it in a certain desired distance. The distance is so important to maintain at the same spot afterwards when you have the cap banks installed. Otherwise would be hard to Tune resonance. and get great outputs
Caps that i use, the red ones, 0.33uF 630 Volts. Poly.
About the Flyback piece I see you did it the Akula way center tap of wire, but I have it the same way the Roundcore has it's Primary coil.  Might be that the akula way could bring something up but again all experimental :).
Make sure the Secondary coil is the same way wound as you will  see the pic below.
Yes, 10 turns is all it takes to be cool, I managed to make another core that holds on to 15 to 20 winds.
Btw the tin wire is just to create induction for the fun of it lol. It's not necessary. It's like looping a wire on the flyback piece and see it burn and melt away. but be carefull alot of heat depending how much in input.
Cheerz
Khwartz
Quote from: tagor on January 13, 2014, 12:24:46 PM
Didier , look at this
http://www.overunity.com/12639/richard-vialles-new-theory-about-negative-mass-and-overunity/#.UtQgw6yweFA
Hi, dear tagor :)
Didn't see that! So very Thanks For sharing, it should save me much time 8)
I have started to go trough to see if I need to add or update something, then I will post the translation of the last exprimental results on the Richard's autogénérateur.
Again: Thanks you do much!  :)
Cheers.
