0 Members and 58 Guests are viewing this topic.
Hoppy
Quote from: Farmhand on February 26, 2014, 05:52:11 PM
I do not understand how people would not realize that the loading of a battery causing current to flow though it would not help to dissolve the hard sulfate.
Cheers
In my opinion this is the major reason why some experimenters are mislead into reporting that their devices display signs of self-running and why after a time they fail to repeat the 'charging' effect after a few operating cycles with an old poorly conditioned battery. I believe that even Bedini has in the past misinterpreted this effect as caused by aetheric / free energy charging. Nick may be reading these posts thinking that we are disinformation freaks / gov agents trying to burst his bubble but I'm sure he will come to realise that there is a lot to learn about battery vagaries and the self-charging effect is just one of them.
Farmhand
Quote from: Hoppy on February 27, 2014, 02:56:14 AM
I've spent quite a bit of time observing the behavior of batteries in different arrangements, I was also confused by it long ago by the claims of the Arfican Guy Promoting Bob Boyce's controller and transformer apparently "self charging" a battery. He claimed that after the night of operation the battery was charged to 13.8 volts, and has been only charging his battery like that for his daughters toy car for some time. Obviously he lied for notoriety or for Bob or to try to justify his initial mistaken claim. It was featured on Peswiki.
One of the reasons I believe nothing they (PesWiki) promote, they wouldn't know if their arse was on fire.  ;D They raised money for him to do more experiments based on his claims. Now I know the effect was simply a vaguery of less than brand new Lead Acid battery function. But did he know it at the time ? Not sure but he still lied about the charging of the battery for the child's toy car. Only way to excuse that is if the claimant admits his folly and apologizes for making false claims and lying. Still won;t mean anyone will trust him again.
Cheers
gmeast
Quote from: Farmhand on February 27, 2014, 04:22:44 AM
Cheers
Hi Farmhand,
I agree with you 100% regarding the behavior of batteries. I have made observations with regards to 'testers' fooling, not only themselves, but also unwittingly stupid investors. If you look at my YouTube slide show on my Inductive Resistor Heater research, you will see that I had to resort to a rather crazy start up procedure to insure good linear discharge of my batteries during both types of tests ... pulsed and resistive loading (outline at the end of the slide show). Specifically, after a lead-acid battery is properly charged (for its type -flooded, gel, AGM, etc.),  and then let to sit and stabilize at a RESTING VOLTAGE (of its choosing... could take hours). when you load it, resistive or pulsed, the battery voltage will drop and then hover at a 'low' plateau and then will begin to rise ... sometimes to above the RESTING VOLTAGE and also hover there for a while and then FINALLY begin a fairly linear drop under a constant load.
I have witnessed demonstrations to investors where the scam artist ONLY demonstrates for the interval leading up to RESTING VOLTAGE. So the scam artist loads the battery (with maybe a light bulb), the voltage drops, he-she-it turns on their 'magic' circuit and the battery begins to 'charge' (or so it seems).  The investor hands over loads of money and ... well, there it is.
I have actually plotted that behavior as part of my tests and presented it in my test data as shown in my posts elsewhere ...  just to account for this so as to be thorough.
Regards,
Greg
gmeast
Quote from: Atommix on February 27, 2014, 08:53:59 PM
Hold back a bit there ! I have charged  a battery over night with a transformer that was not plugged into the grid. I would be happy to open up that a bit wit you ! But if you have so convinced yourself it can not be achieved than who am I to change your mind.
Some things will only happen when you have the correct formula to begin with ! If you just go by chance it may never happen .
Atommix
Hi Atommix,
I'm not sure which specific post you are replying to, or commenting on, but  I'm interested in knowing more about what you mean when you said you:
"have charged a battery over night with a transformer that was not plugged into the grid."
What does that mean exactly?
Thank you,
gmeast
GeoFusion
Quote from: magpwr on February 25, 2014, 06:58:16 AM
hi Geofusion,
I have hit another road block since i only got a 22AWG instead of 26AWG or 28AWG magnet wire to form a tesla coil.
I have calculated in mm that using this magnet wire that i got with 600 turns i will need estimated PVC 39cm in height.
The objective is to do 800...1000turns with around 26AWG or 28AWG within 39cm height.
The setup might look similar to Grumage on the outside but on the center it's where i plan to put the tesla coil(ferrites not decided yet if need to put it in).This would only happen only after i experiment with L/C surrounding the tesla coil just to observe what results i'm getting at resonance of L/C in order to power up the tesla coil.The actual outer pvp pipe(as seen in Akula or Grumage video) inner diameter of the outer pvc pipe would be covered with aluminum tape or (aluminum foil with thin double sided tape add on) at the top portion and half of inner pipe all the way down.Objective to radiate to outer coils.
Like your NST powered Tesla coil video where you bring your hand close and observe sparks to your hand.Just kidding.
I would also need to get a pure-sine wave inverter 500watt...1000watt from ebay.I will lookout for those with free shipment.
The only small notable improvement related to spark length on my 1watt hv circuit is that i have added 1nf capacitor in parallel with the only resistor 1Kohm in the circuit.
I can't use hv flyback transformer for Akula device since the high voltage was already generated by  inverter 220vots to yoke.From virtual experiment i discovered the output from just 1 turns was already creating dangerous high voltage around 1...2KV.
(This is considered high risk experiment)
Hi magpwr :)
ahh  ok . yes true that, you will need a 26 to 28AWG wire for it for sure to manage atleast 1000 winds on the  specific PVC measurement that is needed. I have 28 Gauge but that will be used for the Chubinidze :) soon that I will replicate too.
Yes I have seen Some aluminium covering inside the pvc pipe within Akula's video, yes it's al about resonance of the L/C , Might be that he used aluminium tape, which I have alot here, That might be something that I can use while I have the chance to replicate it soon, and try it out. Oh yeah it's the radiate outer coils with it hehe :)
Haha, yeah the NST tesla coil Project is something different, Besides me touching it and holding it, but it gave me to opportunity to explore the tesla coil very deeply to see what els can be achieved, even with the human body, and have it all in memo :).
But it's limited till their because of the home made salt water caps I used, of X capacitance. all experimental.
I will be showing something els soon , of which I find amazing,
When holding on to the tesla coil and off ground, it seems to Enhance your Vibrational field of your own spiritual energetic body, and electrifying it, so you could turn on lights from a distance passing you hand over them around half a meter/ meter  away.
Yes that is also what you will need man :), pure sine wave inverter, I have mines already, 2 of them, one 800watt and 350watt.
when time comes they will come to use.
Ah alright it's becoming more clearer now for me to know how your flyback circuit has :). Yes simple one indeed , as I have tried many hehe.
Btw the 1nf cap, what is the voltage?
Yes the Yoke is powered by the Circuit and the inverter, but it can only be tweaked with the freq. circuit connected to the IGBT's or mosfets. haha oh yeah, that I have from experience here with some of my experiments, having 2 winds or just 1 , dangerous amount of HV can be produced that can do harm if not carefull.
I've been doing some testings on some other L/C resonance Akula style and seems to be a awesome result of OU. but I will be applying it on my coils see what I can come up with.
Use this setup on your 1 watt hv generator to Tune the frequency. as example
picture below
cheerz :)
