0 Members and 58 Guests are viewing this topic.
MenofFather
Quote from: GeoFusion on March 11, 2014, 03:45:45 PM
MenofFather:
Thank you :) for the uploading and help of the Akula system , it was needed for me to understand it clearer.
Now I could give  a try too and Join the replication group of Akula systems.
Keep in contact with the man, We need his thoughts so we can move forward in replications.
Below I Uploaded a picture of the schematic a bit modified, but is how you mentioned how the coils for output should be should be.
:) take a look.
cheerzz~
You picture is good, but akula not use kacher and he to me write, that kacher not exatly is good, because you can not ground it, buttom end must be grounded.
And I think that kacher frenquency must be same as self oscilation frencuency of output coil to get between them resonance, so here maybe not so easy ajust this. And kacher self oscilations also maybe must be same frenquency and maybe sinshonized with frenquency, one of harmonic of ferite yoke, who is pumped with other frenquency. Let say kacher have 800 kiloherc (then you put it on 6 windings wire, frenquency drobs, here is droped frenquency). Output coil frenquency also must be 800 kiloherc (self resonance, you can chek that with oscilioskope and genrator and find self resonant frenquency) and pumping youke frenquency must be let say 80 kiloherc in resonance. So you must ajust many resonans, but who know, maybe here and no so dificult.
И ещё сдвиг по времени сигналов может быть должен совпадать, поэтому качер может быть не подходит (либо надо как-то это засинхронизировать и сдвигать по времени 80 килогерц частоту от качера частоты может).
00
the simple secret of stand alone overunity is that you have an invertor  coupled to a transformer  ferrite or air core. which is effected by Hf connected to ground wound over the invertor transformer. the output coil is also grounded but wound in opposite direction of the hf coil. the effect of Hf creates an effect which reduces amps draw and works as static flux which interacts with magnetic flux giving  more amps with reduced voltage. this is basic
kapanadze uses two stages one stage he uses to pull ions from ground and feed the above circuit. so he can power  kilowatts loads but principle is same.
zero zero
verpies
Is that your theory or did you verify that experimentally?
DilJalaay
Quote from: 00 on March 12, 2014, 06:27:27 AM
zero zero
Thanks for the post.
could you please picture/diagram, what you said above.
Cheers,
D.J
forest
zero zero
agree, but your explanation is incomplete
