0 Members and 196 Guests are viewing this topic.
Acca
d3x0r
Quote from: Acca on June 18, 2014, 02:48:22 PM
Rusaln – Dally 300 watt schematic  NEW !!...
Link to Rusaln latest clip HD and youtube...
http://www57.zippyshare.com/v/75948948/file.html
http://www.youtube.com/watch?v=tBQeNSObjYw
http://realstrannik.ru/forum/user/6587-topruslan.html
Acca...
THere are many words that google translate doens't like...
pravelnymi
wish someone would fix 'beef' to 'bifilar' in the translator but I got that
Zdyhaet
Scheme well almost pravelnymi  course that's not as Dali and modernized.
Схема ну почти правельная Конечно всё тут не как у Дали , а модернизированно.
And the earth is connected to the inductor and the beef-coil. Without the rest of the land! If you do not connect the ground, will not start. And if you work in time to tear the earth Zdyhaet PSU (impulsnik) By the way, it is better to convert the voltage of 14 volts. Then the better the system works But to repeat the trick the second time I could not work on another now, and as this ekspanat bude.
tried to do a context search on pravelnymi but it fits in a great many ideas that are not congruant?  is it... preliminary?
T-1000
Quote from: d3x0r on June 18, 2014, 03:19:33 PM
"The circuit is almost accurate. Of course everything here not like at Dally but modernized"
Also for you can take a look on page1 of this thread and also compare against http://www.liveinternet.ru/users/edward_lee/
Cheers!
d3x0r
Quote from: T-1000 on June 18, 2014, 03:44:28 PM
Cheers!
Thanx 'accurate' makes sense.
http://realstrannik.ru/forum/39-kapanadze/134730-generatory-kapanadze-obshhaya-tema-2.html?start=3186#222905
some more comments from TOPRuslan... mostly makes sense but he says nothing is grounded except the output.... so how many 'grounds' are there then?  And interestingly enough on Dally seemed everything was tied to the ground point...
"Так вот в одной из коробок в моей установке слева стоит какраз блок питания с такой задержкой. "
"left is my setup kakraz(?) PSU with such a delay"
I see; he also removed the LC tank flywheel... so he's just got a drive coil, the bifilar counter wound coil and the coax...
and a small step-up tl494 in front of the original TL494 to raise that part 24V ... which explains the extra box
@itsu
if you're still around, what were the diodes you found for the DSRD?
Ruslan is still uses the KT926; it is an obsolete part right? like they are no longer being produced?
