0 Members and 70 Guests are viewing this topic.
d3x0r
Quote from: NickZ on July 09, 2014, 09:01:10 PM
   I would also like to see exact coil specs, as well. Like wire gauge, turn counts, winding pattern, etz... I'm certain that he will provide us with the needed info.
   I suppose that Geo is talking about my last pictures of the Akula device, the one below. Or maybe just in general. But, I wonder which coils are too thin gauge, as most all of mine are at least as thick as Akulas. Except for the Exciter secondary coil, which is about 28 gauge, but it can be easily replaced with thicker gauge, if really needed.
  As you can see from the Akula video, his HV sparks are almost invisible, and non shocking as well.  So not much amperage is being provided to the induction circuit that is next to it.  Just HV voltage, with a controlled duty cycle, at least from what I've seen.
  Wesley has refered in Akula's second video, to the diagram that was drawn by someone from the first video. Which has nothing to do with the second video device, and which was not correctly drawn out in the first place. All of this makes for more confusion.
I guess your inner red coil is actually wound on a very thin diameter form?  The outside of the end near HV should be 6 layers total...
Void
I have been away from the forums here for a while now, and just checked in and saw the links to the Akula lantern 3 and 4 videos. Sure, anything in a video could be potentially faked, but I have to say those Akula lantern 3 and 4 videos do look pretty convincing. Ferro-magnetic resonance seems to be what he is saying is producing the excess power which makes these self run, from what I could gather from the videos. Wish I could understand what Akula was saying in those lantern videos, but from what I have seen it seems like there really could be something to it. The excess power has to come from some where, and maybe ferrite does have some unique properties that can be tapped into. Who really knows...
GeoFusion, cool if you can share some more details about what you have done. Small driving impulses causing much larger pulses to occur due to ferro-magnetic resonance. Call me crazy, but it at least sounds plausible. :) GeoFusion, what sort of driving impulse widths are we talking about, if you don't mind saying?
All the best to everyone...
NickZ
   dx30r:
  That is correct on the windings. As I mentioned previously, I still have to wind the 12,12 turns coils, at the end of the induction coils. Just haven't done it yet. But, I will, and I'll also show the finished coil. Including the 3 inch ferrite rod as a choke in the center, joining the Exciter's secondary coil to the big red HV coil on the outside of induction coil side. As the pvc coil former is also telescopic, it can be adjusted in or out, as needed. As the nearness of one coil crt to the other crt, may need some tuning, as well.
   All that I see that can be happening there is simply, that the HV pulses from the exciter is pulsing the the induction crt's output coil. While the mosfet feed induction circuit is also pulsing magnetic current out.  Both at the same time, in sinc and in resonance. Of course, there's more to it, with all the the coils and their combined effects. Like with the 12,12 turn feed back coil that I need to wind on the end of the induction coil side, and what it's role can be in the total effect generation.
  That's about where I'm at with this, at the moment.
zcsaba77
Quote from: magpwr on July 09, 2014, 12:32:36 PM
hi zcsaba77,
It's simple aim for the metal to get hot/warm inside coil as a rough guide.
Parallel L/C resonance plays a very important role which should closely match yoke core output frequency.
At this point i need to be honest for Nick's experiment-
For Nickz's experiment to be successful in order to get a "thick coil" with suitable high voltage capacitor\capacitors  connected in parallel\induction heater capacitor and this would function as a induction heating coil if metal is placed in it.
Maybe I something missed, the induction heater test is without ferrite core, and we must adjust frequency to the ferrite cored one,
its hard to compare these thing, make good result for both ones!
Gentle reminder we are not creating a induction coil for heating purpose.Placing metal in it would merely let us know if there is sufficient power in the coil which then act as primary coil for the "multi layered coil/secondary coil"
To save time-He would need an "oscilloscope" to obtain the "frequency" output from yoke core.
After which he would need to wind a "thick primary coil" only without secondary layered coil in order to simplify\verify output power from pri coil.
Yes this true everyone who not want lossing the time, need 'good' scope, with 2 or more probes (I just have pocket one with 1 probe)
L/C meter is needed to derive the uH reading of the "thick coil"
Then use online L/C calculator eg: http://www.mackrackit.com/djm/Web/LCR/LCR.html
Then apply the uH reading(This is static value.Unless you rewind the coil)
Also L/C meter is 2nd necessary thing, but these web L/C calculator working on base air core, if I good know, please correct me if not!
Then apply any capacitor value in nf(Apply few times by increasing or decreasing cap value) which will closely matched the yoke frequency.
Once the capacitor value is known.This would be capacitor/capacitor in parallel to match the actual capacitor value to use.L/C meter is needed to verify capacitance value never trust value written on cap.
And finnaly we speak (yoke) ferrite cored transformer, if I good remmeber on shematic was just 1 generator from 2 (or 3, I dont know),
and on this transformer was just 2 coil, primary cw+ccw middle tapped, and secondary usualy winded, and output goes to 2nd (so much mentioned multi layer) transformer where meets sinus and pin peaks impulses (if I good understood from posts/videos),
so Im now disordered, with your explanation, how meet primary coil with multi layered coil on one yoke? (if we speak Akulas/Dallys/Ruslans device)
regards zcsaba77
GeoFusion
Hi guyz  :)
It's pretty late here, 1:20am
but still up.
  Hoppy:
:) it will all come.
  a.king21:
Yes, the wire gauges especially when they are thicker at some part of the coiling is important for greater output.
I will gladly show the schematics yet the video soon and upclose too. :)
Nickz:
You will see everything on the schematic, but when you have to circuit, you could try out many forms of Coilings too, but with the proper directions.
Btw the Tesla coil (kacher) 28guage can do, I am using 24gauge magnet wire.
the energy the tesla coil produces is actually hot radiant plasma at the end if you don't connect it as it is in the second akula video.
It burns your finger :). so we need to be careful there. It's only working on a 2N3055 Power Transistor and a perfect circuitry that can handle
pressure, up till 12V~ 48V.
it's all to be tuning to the right frequencies using the potentiometers within the IC circuits.
I am suspecting by my build that even the first akula free energy device of @700watts of power, even without ground he used, is quite easy to build if you have the right Running capacitors. :) and uses almost the same yoke ferrite core setup for impulses.
  Void:
Yes of course man, I will manage to see how I share my details but I will share the diagrams and schematics I used that helped me out :).
yes ,impulses is all needed here and to further achieve resonance with, ferrite yoke is really vital in this circuitry sins it produces alot of amps for the induction process.
I have no problem you asking what  driving impulse I'm using in what range.
The driving impulse widths are in Khz.  you could say in between 17 - 27 - 37Khz for the Induction part with impulses.
Tesla coil must be Around it's 190's Khz or 150's. The scalar waves amplifies the output too for the output coils.
This will be the first Schematic of the oscillator for you guyz to be analyzing  and to try it out.
The circuitry I used with almost exact same components.
This is the one connected to the Ferrite Yoke.
Unlike the Mazilli/heater circuit I used, It's now much more , using these IC's TL494's. In my device, I have other mosfets in place.
Be careful! this circuit is not a toy!
