0 Members and 242 Guests are viewing this topic.
a.king21
Quote from: NickZ on July 12, 2014, 12:58:56 PM
   Geo:
   Ok, I'm confused. Are you suggesting that the HV pulser coils, and it's driver circuit are not totally essential, nor is hererodyning along with the induction generator circuit part. As a SELF RUNNER, at least to some degree.   A simple yes, or no would help.
   I would be into building up the fairly simple circuit that you are suggesting. But, I still need to obtain the proper 18v zeners, which have not been delivered to me yet. They should be here soon.
  Is this the circuit (below) that you built? Just checking to be sure. As all these schematics being posted are all different. As well as the coil winding designs.
Akula winds his (air coils) output coil in the same direction. Only the air core primary is bifilar.  Or not?
Can someone please break this circuit up into sections so we can understand what each part does?
Hoppy
Nick,
Given that the full schematic posted by Geo cannot possibly run without a power supply, I suspect that Geo relies on a permanent battery supply which appears to charge under load. I say this as this would explain the Karcher, HV generator, which from my experiments causes an apparent potentialisation of the supply battery to give the impression that the battery is actually charging under load, especially when the battery is initially connected and adjusting its internal resistance to applied load. This is why I think that if and when Geo does eventually post his video, it will show a permanent connection to a battery supply. It will be important for Geo to demonstrate that the device is capable of true self-running by clearly showing the battery being disconnected whilst running. Akula is able to disconnect his battery, as he has an alternative hidden power supply. Of course, Geo could also do this but I believe he is above producing a faked video.
MenofFather
Quote from: a.king21 on July 12, 2014, 01:57:01 PM
Voltage stabiliser can be nessary for driver if you run system from 24 or more volts.
NickZ
   MenofFather:
   Thanks for the separation of component blocks, and explanations of the schematic.
   Hoppy:  I can see that it will take more than a witness's declaration as was shown by Tiger, to convince you that the Akula second device is NO FAKE!  That device is what I'm really trying to replicate, in my own way, using Akula's own schematic as a reference.
   If Geo's schematic can lead to a self runner, I'm up for that as well.
   Also, If Geo's device works with a battery connected, or not, yet can still self run for a time span that is much much much longer than would be provided by that battery alone, it is still of value. And can be considered a self runner, or at least a "long runner".
  He may not ever show his device, as there may be more than just good members on this thread, as well and on the other forums. But, I hope that he will, in spike of anything that might happen.  As I don't want to add more to this idea, I will refrain from further mention of it.
  At least on my Mazilli/yoke circuit's feed back loop, there is power being sent back to the input. Or both to the oscillar input as well as the battery. But, not enough power to self run yet without the battery.
  It will all come together though, just a matter of time, for one of us to show a self runner, and someone else like yourself (our house detective) to replicate it.
GeoFusion
Hi Guyz :)
   Nick:
There is nothing to be confused about here man, take a good look at these schematics, try to understand.
the circuits you see in the schematic are very essential to this system. Yes Heterodyning is used here, Radio signals.
You need to make the Circuit  "beat" like a heart is beating.
Example.  Just like a Motor generator have pulsed rotor that keeps the voltage constant.
You need this to work and tune it correctly, you will need measuring equipment to measure the outputs and what input the circuitry needs to stay alive. and you will see you can Self feed it back to the circuits without a battery! :)
Yes that particular circuit you see in the schematic I have build that circuit and also modified ti too, also have build one that can have more than 120Vdc+.
Just need to try them out without fear, That is how I do, I really don't mind passing thru many circuits as what I have done allot, but this is the reall McCoy ideas.
The primary winds that is connected in the L/C is bifilar and the output windings are bifilar but you could also try out single layer output coils.
   Hoppy:
Yes, soon enough I will post some pics and videos as promised but it's best to investigate the circuit and understanding it. But I really don't want to be in the spot light just yet.
But I will slowly show parts that I use within the circuitry.
Btw, it does and can run without a battery,  this circuit setup and the entire device makes sense now why I couldn't get my older experiments to self feed , just as my RMG  circuit. it misses Radio frequency pulses, beating heart. A pulse.
:) it also has a ground connection too.
   Jeg:
:) yes It somehow does, but the 2.2nF cap is to the part of protection of the circuit called a " Snubber".
the Zeners faced eachother If I'm correct that is a Overvoltage protection.
And no, 190khz is not there. that can be around the kacher part.  but the part of the circuit with TL494 is where you must be tuning in between 15- 17-27- 37- 50Khz in the range. for the L/C resonance. Depends your coils and  cap for the frequency.
Thanks for the help Meno :).
For the schematic:
The Choke is around 47-100uH is what I used.
You also have at the mosfets, Overvoltage protection, and a snubber, They are essential, thinking when tuning it with capacitor for the L/C resonance.
